Imx6q is allowing me to fuse MAC address twice
Rojesh
I'm using the below script to fuse my imx6q boards MAC address. It's allowing me to fuse the MAC address twice. After the second time it's not allowing me to fuse
#FB: ucmd setenv fastboot_dev mmc
#FB: ucmd setenv mmcdev ${emmc_dev}
FB: ucmd fuse sense 4 2
FB: ucmd fuse sense 4 3
FB: ucmd fuse sense 0 6
FB: ucmd fuse prog 4 2 4AF00005
FB: ucmd fuse prog 4 3 0023
FB: ucmd fuse prog 0 6 0x100000
# Download Kernel to be executed from RAM
FB: ucmd setenv fastboot_buffer ${loadaddr}
FB: download -f zImage
# Download DTB
FB: ucmd setenv fastboot_buffer ${fdt_addr}
FB: download -f imx6q-consoleui.dtb
Can you please guide me on where it's going wrong?
Harvey021
Hi @Rojesh
A fuse corresponds to a single non-volatile memory bit that can be programmed(i.e. blown, set to 1) only once. The programming operation is irreversible. A fuse that has not been programmed reads 0.
Harvey
