Imx 6 quad login service failed
arzhakov5
Hello. Help me please!
On Linux 5.4.24_2.1.0 I've got a problem when device boots:
[FAILED] Failed to start Login Service.
...and others problems...
Can anyone help?
arzhakov5
Probably, this image does not fit at all with this device. Thanks so much for trying to help!
May I ask for delete this topic?
arzhakov5
Device is Lilliput PC-9715
Rita_Wang
If you are using the third company board and BSP, they maybe change the password, you need to confirm with them.
Rita_Wang
Is it NXP board? I do not see this you send.
arzhakov5
Unfortunately, when I'm trying to login as root, the system answers: "Login incorrect".
Rita_Wang
The password is "root" for default BSP. Could you tell us which board are you using? NXP board or others? For images are you using the demo images?
