Probably, this image does not fit at all with this device. Thanks so much for trying to help!
May I ask for delete this topic?
Device is Lilliput PC-9715
If you are using the third company board and BSP, they maybe change the password, you need to confirm with them.
Is it NXP board? I do not see this you send.
Unfortunately, when I'm trying to login as root, the system answers: "Login incorrect".
The password is "root" for default BSP. Could you tell us which board are you using? NXP board or others? For images are you using the demo images?
