Implement android 11 BSP, but always stop on the dts' &group5 setting
i_MX51
Dear
when i implement the android-11.0.0_1.0.0 BSP on the imx8mq-evk board, the console message always freezes on the message "GPIO line 157 (wl-reg-on) hogged as output/high", it should be the dts content(&gpio5), anybody knows what' problem with it ?
ps. i try to download the release image, it is the same problem! and i try to disable the most dts' devices, it is the same.
thanks
Zhiming_Liu
Did you try other version? Or only this version has issue?
