Image problem for imx95
756 次查看
OlivierG
I created an image for imx95 in full mode.
Once I had the image, to flash the image to an SD card, I ran:
sudo dd if=imx-image-full-imx95-95-19x19-verdin.rootfs.wic of=/dev/sda bs=1M $$ sync
The "root" volume is correct.
But the "boot" volume is incorrect.  Instead of being named "boot," it's named "268 MB volume" and it's empty.
Obviously, this SD card won't boot.
What's the problem?
Is there an existing full imx95 verdin image?
Greetings
Olivier
5 回复数
402 次查看
OlivierG
I use a IMX 95 verdin toradex A1 (not a B0)
The current Yocto on gitlab is made for B0
i get a prebuild image for A1 , it works
Olivier
735 次查看
OlivierG
finally the boot volume is present
But the image dos not boot , no log on the debug channel, no screen display
i have a Toradex  IMX95 Verdin EVk
i build the kernel with
MACHINE=imx95-19x19-verdin
is it right ?
Olivier
727 次查看
Manuel_Salas
Hello @OlivierG
I hope you are doing very well.
Could you please share your part number?
Also, Have you tried flashing the image with UUU tool instead with the direct dd command?
In our BSP we support the Machine imx95-19x19-verdin, so it is correct.
Salas.
697 次查看
OlivierG
i launch : sudo uuu -lsusb
i get
uuu (Universal Update Utility) for nxp imx chips -- lib1.5.141
Connected Known USB Devices
Path Chip Pro Vid Pid BcdVersion
1:2 MX95 SDPS: 0x1FC9 0x015D 0x0001
i launch
sudo uuu -b sd imx-boot-imx95-19x19-verdin-sd.bin-flash_all
i get
Success 0 Failure 1
1:2 1/ 1 [HID(W):LIBUSB_ERROR_NO_DEVICE ] SDPS: boot -f imx-boot-imx95-19x19-verdin-sd.bin-flash_all
These commands are launch from a Linux ubuntu 24
Where is the problem ?
Olivier
626 次查看
Manuel_Salas
Hello @OlivierG
Please try with:
$ sudo uuu -b sd_all imx-boot-imx95-19x19-verdin-sd.bin-flash_all <your image.wic>
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-2159186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx95%20%E7%9A%84%E5%9B%BE%E5%83%8F%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%9C%A8%E5%85%A8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%B8%BA%20imx95%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9C%89%E4%BA%86%E6%98%A0%E5%83%8F%E5%90%8E%EF%BC%8C%E6%88%91%E8%BF%90%E8%A1%8C%E4%BA%86%E5%B0%86%E6%98%A0%E5%83%8F%E9%97%AA%E5%AD%98%E5%88%B0%20SD%20%E5%8D%A1%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Esudo%20dd%20if%3Dimx-image-full-imx95-95-19x19-verdin.rootfs.wic%20of%3D%2Fdev%2Fsda%20bs%3D1M%20%24%24%20sync%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%22%E6%A0%B9%22%20%E5%8D%B7%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BD%86%E6%98%AF%20%22%E5%90%AF%E5%8A%A8%22%20%E7%9A%84%E9%9F%B3%E9%87%8F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%22%20%E5%AE%83%E6%B2%A1%E6%9C%89%E8%A2%AB%E5%91%BD%E5%90%8D%E4%B8%BA%20%22%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E8%80%8C%E6%98%AF%E5%90%8D%E4%B8%BA%20%22%20268%20MB%20%E5%8D%B7%20%22%20%E8%80%8C%E4%B8%94%E6%98%AF%E7%A9%BA%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%98%BE%E7%84%B6%EF%BC%8C%E8%BF%99%E5%BC%A0%20SD%20%E5%8D%A1%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%AE%8C%E6%95%B4%E7%9A%84%20imx95%20verdin%20%E5%9B%BE%E5%83%8F%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%82%A8%E5%A5%BD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Image%20problem%20for%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20IMX%2095%20verdin%20toradex%20A1%EF%BC%88%E4%B8%8D%E6%98%AF%20B0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%20gitlab%20%E4%B8%8A%E7%9A%84%20Yocto%20%E6%98%AF%E4%B8%BA%20B0%20%E5%88%B6%E4%BD%9C%E7%9A%84%3C%2FP%3E%3CP%3E%E6%88%91%E8%8E%B7%E5%BE%97%E4%BA%86%20A1%20%E7%9A%84%E9%A2%84%E6%9E%84%E5%BB%BA%E6%98%A0%E5%83%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%3C%2FP%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Image%20problem%20for%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245939%22%20target%3D%22_blank%22%3E%40OlivierG%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20sudo%20uuu%20-b%20sd_all%20imx-boot-imx95-19x19-verdin-sd.bin-flash_all%20%3CYOUR%20image.wic%3D%22%22%3E%3C%2FYOUR%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%90%A8%E6%8B%89%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Image%20problem%20for%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245939%22%20target%3D%22_blank%22%3E%40OlivierG%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E6%82%A8%E7%9A%84%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20UUU%20%E5%B7%A5%E5%85%B7%E9%97%AA%E5%AD%98%E9%95%9C%E5%83%8F%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%20dd%20%E5%91%BD%E4%BB%A4%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%94%AF%E6%8C%81%E6%9C%BA%E5%99%A8%20imx95-19x19-verdin%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%90%A8%E6%8B%89%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Image%20problem%20for%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%BB%88%E4%BA%8E%E6%9C%89%E5%90%AF%E5%8A%A8%E9%9F%B3%E9%87%8F%E4%BA%86%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%98%A0%E5%83%8F%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%EF%BC%8C%E8%B0%83%E8%AF%95%E9%A2%91%E9%81%93%E4%B8%8A%E6%B2%A1%E6%9C%89%E7%99%BB%E5%BD%95%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%B1%8F%E5%B9%95%E6%98%BE%E7%A4%BA%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%20Toradex%20IMX95%20Verdin%20EVk%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%E5%AE%83%E6%9D%A5%E7%89%88%E6%9C%AC%E5%86%85%E6%A0%B8%3C%2FP%3E%3CP%3EMACHINE%3Dimx95-19x19-verdin%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%B8%8D%E5%AF%B9%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
