hi,
I am going to reduce the PCB-size and bom of the design,so I will delete all the parts if they are not useful.
1:If I don't use USB HOST,do the USB_H1_VBUS need to power by 5V?
2:If I don't use LVDS0 and LVDS1,do the NVCC_LVDS2P5 pin need to power?
3:If I don't use SATA-PCIE-DSI-LVDS,do the their REXT pins need to connect Resistor?
4:how to use the pin of test_mode,tamper,onoff? Can I float these pins if I do not use them?
By the way,can u give me the file of how to deal for unuse pins?
thanks.
Hi 翔李
please look at sect.2.8 Unused analog interfaces i.MX6 System Development User’s Guide
https://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
