Hi @jgsandom
I'm taking the OV2775 sensor reference for porting the IMX219.
Now able to get the video nodes on v4l2-ctl command.
I'm using the following command to get the stream and attaching the output log.
root@imx8mpevk:/opt/imx8-isp/bin# ./video_test -w 1920 -h 1080 -f RAW10 -t file -m0 -d2
[ 506.302106] Enter mipi_csis_clk_enable ...
[ 506.306609] Enter mipi_csis_clk_enable ...
[ 506.311173]
[ 506.311173] enter imx219_priv_ioctl ((( (cmd = -2140645888))))
[ 506.318604] Command : VIDIOC_QUERYCAP
[ 506.322901] enter (( imx219_ioc_qcap ))
[ 506.327076] enter dwe_runtime_resume ....
[ 506.331451] enter dwe_enable_clocks ....
[ 506.335747] enter dwe_open ....
[ 506.349623] enter dwe_close ....
[ 506.365599] enter dwe_runtime_suspend ....
[ 506.378250] Enter mipi_csis_clk_enable ...
[ 506.382773] Enter mipi_csis_clk_enable ...
[ 506.387275]
[ 506.387275] enter imx219_priv_ioctl ((( (cmd = -2140645888))))
[ 506.394742] Command : VIDIOC_QUERYCAP
[ 506.399052] enter (( imx219_ioc_qcap ))
[ 506.403154] Enter mipi_csis_clk_enable ...
loading [IMX219.drv]...
[ 506.427968] Enter mipi_csis_clk_enable ...
[ 506.434057] Enter mipi_csis_clk_enable ...
[ 506.438550]
[ 506.438550] enter imx219_priv_ioctl ((( (cmd = -2140645888))))
[ 506.445963] Command : VIDIOC_QUERYCAP
[ 506.450243] enter (( imx219_ioc_qcap ))
[ 506.454310] enter dwe_runtime_resume ....
[ 506.458677] enter dwe_enable_clocks ....
[ 506.462967] enter dwe_open ....
IMX219_IsiQuerySensorSupportIss (enter)
WARN : [DEWARP_HW] dwe type /dev/v4l-subdev0 0
WARN : [DEWARP_HW] dwe type /dev/v4l-subdev1 1
WARN : [DEWARP_HW] dwe type /dev/v4l-subdev2 2
WARN : [DEWARP_HW] dwe type /dev/v4l-subdev3 3
Video Test:caps supports:{
count = 1
index = 0
width = 1920
height = 1080
fps = 30
hdr_mode = 0
[ 506.516725] enter imx219_priv_ioctl ((( (cmd = 290))))
[ 506.525407] Command : VVSENSORIOC_G_SENSOR_MODE
[ 506.530563] enter (( imx219_g_mode ))
[ 506.534435] sensor->cur_mode.index = 0 pmode->index = 0 sensor->cur_mode.width =1920 sensor->cur_mode.height =1080
IMX219_IsiGetSensorIss ((enter))
IMX219_IsiGetSensorIss ((exit))
IMX219_IsiCreateSensorIss (enter)
IMX219_IsiCreateSensorIss (exit)
IMX219_IsiInitSensorIss (enter)
[ 506.584657] enter isp_mi_stop
IMX219_IsiInitSensorIss (exit)
IMX219_IsiGetSensorModeIss (enter)
IMX219_IsiGetCapsIss (enter)
Bus width == 10
IMX219_IsiGetCapsIss (exit)
isp input: 1920x1080 RAW10
isp output: 1920x1080 YUV422I
dewarp input: 1920x1080 YUV422I
dewarp output: 1920x1080 YUV422I
IMX219_IsiSetupSensorIss (enter)
IMX219_IsiSetupSensorIss IMX219 System-Reset executed
[ 506.691954]
[ 506.691954] enter imx219_priv_ioctl ((( (cmd = 283))))
[ 506.698675] Command : VVSENSORIOC_S_HDR_MODE
[ 506.703596] enter (( imx219_s_hdr ))
[ 506.707375] HDR Selected = 0
[ 506.710721]
[ 506.710721] enter imx219_priv_ioctl ((( (cmd = 294))))
[ 506.717444] Command : VVSENSORIOC_S_SENSOR_MODE
[ 506.722692] enter (( imx219_s_sensor_mode ))
[ 506.727150] Mode Selected = 0
[ 506.730309] enter (( imx219_set_fmt ))
[ 506.734241] enter (( imx219_write_reg_arry ))
[ 506.738779] enter imx219_write_reg_arry
IMX219_AecSetModeParameters: (enter)
IMX219_AecSetModeParameters: AecMaxIntegrationTime = 0.033298
IMX219_AecSetModeParameters: (exit)
IMX219_Private_SetFormat: 1920 1080 0
[ 506.805845] enter (( imx219_get_format_code ))
[ 506.810514] Bayer pattern selected == 2
IMX219_IsiSetupSensorIss (exit[ 506.814723]
[ 506.814723] enter imx219_priv_ioctl ((( (cmd = 264))))
[ 506.824382] Command : VVSENSORIOC_WRITE_REG
[ 506.829280] enter (( imx219_write_reg ))
[ 506.833388] Write reg : reg=601, val=3
IMX219_IsiActivateTestPatte[ 506.839040]
[ 506.839040] enter imx219_priv_ioctl ((( (cmd = 285))))
[ 506.847093] Command : VVSENSORIOC_S_FPS
[ 506.851561] enter (( imx219_s_fps ))
[ 506.855339] FPS SET = 30
IMX219_IsiRegisterWriteIss (enter)
[ 506.858425]
[ 506.858425] enter imx219_priv_ioctl ((( (cmd = 290))))
[ 506.867980] Command : VVSENSORIOC_G_SENSOR_MODE
[ 506.873133] enter (( imx219_g_mode ))
[ 506.876981] sensor->cur_mode.index = 0 pmode->index = 0 sensor->cur_mode.width =1920 sensor->cur_mode.height =1080
IMX219_IsiRe[ 506.887801]
[ 506.887801] enter imx219_priv_ioctl ((( (cmd = 286))))
[ 506.897368] Command : VVSENSORIOC_G_FPS
[ 506.901829] enter (( imx219_g_fps ))
[ 506.905586] GET FPS = 30
[ 506.908345] enter imx219_priv_ioctl ((( (cmd = 276))))
[ 506.915058] Command : VVSENSORIOC_S_EXP
[ 506.919515] enter (( imx219_s_exp ))
[ 506.923274] enter (( imx219_write_reg ))
[ 506.927383] Write reg : reg=15a, val=ff
[ 506.932849] (exit) result = 0
[ 506.932849] enter imx219_priv_ioctl ((( (cmd = 279))))
[ 506.941179] Command : VVSENSORIOC_S_GAIN
[ 506.945736] enter (( imx219_s_gain ))
[ 506.949581] enter (( imx219_write_reg ))
[ 506.953688] Write reg : reg=157, val=c8
IMX219_IsiActivateTestPattern[ 506.959259] .. Enter mipi_csis_clk_enable ...
[ 506.965207] Enter csis_s_fmt ...
[ 506.968727] Enter find_csis_format ...
[ 506.972751] Enter disp_mix_gasket_config ...
[ 506.977297] Enter mipi_csis_set_params ...
[ 506.981662] Enter __mipi_csis_set_format ...
[ 506.986201] fmt: 0x2008, 1920 x 1080
[ 506.990305] Enter mipi_csis_set_hsync_settle ...
[ 506.995247] Enter mipi_csis_clk_enable ...
[ 506.999780] enter isp_s_comp
[ 507.002682] enter isp_s_comp
[ 507.005564] enter isp_s_comp
[ 507.008514] Enter mipi_csis_clk_enable ...
[ 507.012949] Enter mipi_csis_s_stream ...
[ 507.017157]
[ 507.017157] Enable = 1 state = 0x0
[ 507.022137] Enter mipi_csis_sw_reset ...
[ 507.026354] Enter mipi_csis_start_stream ...
[ 507.030895] Enter disp_mix_gasket_config ...
[ 507.035440] Enter mipi_csis_set_params ...
[ 507.039810] Enter __mipi_csis_set_format ...
[ 507.044350] fmt: 0x2008, 1920 x 1080
[ 507.048460] Enter mipi_csis_set_hsync_settle ...
[ 507.053363] Enter mipi_csis_system_enable ...
[ 507.057997] Enter disp_mix_gasket_enable ...
[ 507.062543]
[ 507.062543] Enter mipi_csis_clean_irq ...
[ 507.068123]
[ 507.068123] Enter mipi_csis_enable_interrupts ...
IMX219_IsiSetSensorFpsIss (enter)
IMX219_IsiSetSensorFpsIss: set fps(0) out of range, correct to 0 (0, 0)
IMX219_IsiSetSensorFpsIss set sensor fps = 0
IMX219_IsiSetSensorFpsIss (exit)
[ 507.094680] enter wdr3_hw_init
IMX219_IsiGetGainLimitsIss (enter)
[ 507.098550] wdr3 res: 1920 1080
Min Gain = 1.000000 Max Gain = 21.000000
[ 507.105342] enter isp_mi_start
[ 507.111282]
[ 507.111282] enter imx219_priv_ioctl ((( (cmd = 274))))
[ 507.120137] >>> Command : VVSENSORIOC_S_STREAM
IMX219_IsiGetGainLimitsIss (exit)
[ 507.124865] enter (( imx219_s_stream )) control value = 1
IMX219_IsiGetIntegrationTimeLimitsIss (enter)
[ 507.133292] enter (( imx219_write_reg ))
[ 507.140257] Write reg : reg=100, val=1
Min INtegration Time = 0.000030 Max Int time = 0.033298
IMX219_IsiGetIntegrationTimeLimitsIss (exit)
IMX219_IsiGetSensorFpsIss (enter)
IMX219_IsiGetSensorFpsIss (exit)
IMX219_IsiExposureControlIss (enter)
IMX219_IsiExposureControlIss: g=1.000000, Ti=0.000030
==>> HDR Mode = 0
IMX219_IsiSetIntegrationTimeIss (enter)
IMX219_IsiSetIntegrationTimeIss: set AEC_PK_EXPO=0x00001
IMX219_IsiSetIntegrationTimeIss Ti=0.000030
IMX219_IsiExposureControlIss: set: NewGain=1.000000, hcgTi=0.000030, hcgskip=1
IMX219_IsiSetGainIss (enter)
IMX219_IsiSetGainIss g=1.000000
IMX219_IsiExposureControlIss: set: vsg=1.000000, vsTi=0.000030, vsskip=1
IMX219_IsiExposureControlIss (exit)
#### CsiSetFormat 1920 1080 808534599
CamEngineEnableCproc: set val 1 1 1 1.10 -15 1.00 0.00
IMX219_IsiSensorSetStreamingIss (enter)
IMX219_IsiSensorSetStreamingIss (exit)
As I can see, till Start Streaming API called and proper value is written to the register.
But there is no streaming.
./video_test -w 1920 -h 1080 -f RAW10 -t file -m0 -d2 is the command used.
I'm using the Ov2775 xml file for IMX219. Will this cause an issue?
Also can you point out the area where i can look into?
Thanks and Regards
Charles
