ISP Usage of i.MX 8M series
JK_Cha
Hi NXP
Can you please let me know if iMX 8M or other series able to support internal ISP subsystem?
I can find only samll information about CSI interface.
Should I recommend customer to use external ISP rather than Processor internal ISP?
Thanks.
James
JK_Cha
Hi Joanxie
Thanks for your kind answer.
Can you please let me know if the i.mx 8 series able to support both ISP and MJPEG for IP Camera application?
James
joanxie
yes, can support
JK_Cha
Hi Joanxie
In the case of 8M Plus, ISP is confirmed in Datasheet/TRM, but mjpeg is not confirmed. Can you tell me where to look?
Thanks.
joanxie
document doesn't mention this
JK_Cha
Hi Joanxie
Then I can tell the customer that iMX8MPLUS supports ISP and MJPEG, right?
Jack
joanxie
what detailed MJPEG the customer need? do they need capture video from camera then encode to the MJPEG or they need MJPEG decode from MJPEG video to the other format?
joanxie
i.mx8mp has internal ISP, you can refer to the reference manual, nxp also has been released many application notes, you can refer to the link as below
"https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces..."
