I try to use the IPU IC to convert images in the post-processor (fmem channel 11 -> fmem channel 22).
Things work as expected on an iMX6Q but operation is stuck on iMX6QPlus.
A simple reproducer on Linux (Kernel 6.1) is
gst-launch-1.0 videotestsrc num-buffers=1 \! \ "video/x-raw,format=NV12,width=256,height=128" \! \ v4l2convert \! "video/x-raw,width=128" \! \ filesink location=/tmp/a
It finishes on iMX6Q but hangs on iMX6QPlus. It uses the
| # v4l2-ctl -d /dev/video8 --all | Driver Info: | Driver name : imx-csc-scaler | Card type : imx-csc-scaler | Bus info : platform:imx-csc-scaler
device.
iMX6QPlus has a new prefetcher unit but afais, it is related to the display related dma channels. What has been changed else resp. what must be done to use the IC again?
More examples: after
strace output
ioctl(6, VIDIOC_QUERYCAP, {driver="imx-csc-scaler", card="imx-csc-scaler", bus_info="platform:imx-csc-scaler", version=KERNEL_VERSION(6, 1, 8), capabilities=V4L2_CAP_VIDEO_M2M|V4L2_CAP_EXT_PIX_FORMAT|V4L2_CAP_STREAMING|V4L2_CAP_DEVICE_CAPS, device_caps=V4L2_CAP_VIDEO_M2M|V4L2_CAP_EXT_PIX_FORMAT|V4L2_CAP_STREAMING}) = 0 ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=720, height=576, pixelformat=v4l2_fourcc('Y', 'U', '1', '2') /* V4L2_PIX_FMT_YUV420 */, field=V4L2_FIELD_NONE, bytesperline=720, sizeimage=622080, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, fmt.pix={width=720, height=576, pixelformat=v4l2_fourcc('Y', 'U', '1', '2') /* V4L2_PIX_FMT_YUV420 */, field=V4L2_FIELD_NONE, bytesperline=720, sizeimage=622080, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 ioctl(6, VIDIOC_S_FMT, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_ANY, bytesperline=0, sizeimage=0, colorspace=V4L2_COLORSPACE_DEFAULT}} => {fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 ioctl(6, VIDIOC_REQBUFS, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, memory=V4L2_MEMORY_MMAP, count=3 => 3}) = 0 ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0 ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=1, memory=V4L2_MEMORY_MMAP, m.offset=0x8000, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0 ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=2, memory=V4L2_MEMORY_MMAP, m.offset=0x10000, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0 ioctl(6, VIDIOC_S_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_ANY, bytesperline=0, sizeimage=0, colorspace=V4L2_COLORSPACE_DEFAULT}} => {fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 ioctl(6, VIDIOC_S_CTRL, {id=V4L2_CID_HFLIP, value=1 => 1}) = 0 ioctl(6, VIDIOC_REQBUFS, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, memory=V4L2_MEMORY_MMAP, count=1 => 1}) = 0 ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0x40000000, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0 ioctl(6, VIDIOC_STREAMON, [V4L2_BUF_TYPE_VIDEO_CAPTURE]) = 0 ioctl(6, VIDIOC_STREAMON, [V4L2_BUF_TYPE_VIDEO_OUTPUT]) = 0 ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, bytesused=32768, timestamp={tv_sec=1002, tv_usec=107967}, sequence=0, ...}) = 0 ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=1, memory=V4L2_MEMORY_MMAP, m.offset=0x8000, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, bytesused=32768, timestamp={tv_sec=1002, tv_usec=108260}, sequence=0, ...}) = 0 ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=2, memory=V4L2_MEMORY_MMAP, m.offset=0x10000, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, bytesused=32768, timestamp={tv_sec=1002, tv_usec=108451}, sequence=0, ...}) = 0 ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0x40000000, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0
the IPU is configured with
0x02600000 CONF 0x0000'0004 CSI0_EN : false CSI1_EN : false IC_EN : true IRT_EN : false DP_EN : false DI0_EN : false DI1_EN : false SMFC_EN : false DC_EN : false DMFC_EN : false SISG_EN : false VDI_EN : false IDMAC_DIABLE : false DMFC_SEL : IDMAC DMFC_SYNC : async CSI0_DAT_SOURCE : parallel CSI1_DAT_SOURCE : parallel IC_INPUT : CSI CSI_SEL : CSI0 0x0260003c INT_CTRL_EOF_0 0x10c0'0800 0x02600040 INT_CTRL_EOF_1 0x0004'8000 0x02600200 INT_STAT_EOF_0 0x0000'0000 0x02600204 INT_STAT_EOF_1 0x0000'0000 0x02600208 INT_STAT_NFACK_0 0x0000'0800 0x0260020c INT_STAT_NFACK_1 0x0000'0000 0x02600210 INT_STAT_NFB4EOF_0 0x0000'0000 0x02600214 INT_STAT_NFB4EOF_1 0x0000'0000 0x02600218 INT_STAT_EOS_0 0x0000'0000 0x0260021c INT_STAT_EOS_1 0x0000'0000 0x02600220 INT_STAT_9 0x0000'0000 0x02600224 INT_STAT_10 0x0000'0000 0x02600228 INT_STAT_EOBND_0 0x0000'0000 0x0260022c INT_STAT_EOBND_1 0x0000'0000 0x02600230 INT_STAT_TH_0 0x0000'0000 0x02600234 INT_STAT_TH_1 0x0000'0000 0x02600238 INT_STAT_15 0x0000'0000 0x0260023c CUR_BUF_0 0x0000'0000 0x02600240 CUR_BUF_1 0x0000'0000 0x02600268 CH_BUF0_RDY0 0x0040'0800 0x0260026c CH_BUF0_RDY1 0x0000'0000 0x02600270 CH_BUF1_RDY0 0x0000'0000 0x02600274 CH_BUF1_RDY1 0x0000'0000 ======================== IPU1-IDMAC ============================== 0x02608000 CONF 0x0000'002f MAX_REQ_READ : 7 WIDPT : 1 RDI : true P_ENIAN : false USED_BUFS_MAX_W : 0 USED_BUFS_EN_W : false USED_BUFS_MAX_R : 0 USED_BUFS_EN_R : false 0x02608004 CH_EN_1 0x0040'0800 0x02608100 CH_BUSY_1 0x0000'0000 0x02608104 CH_BUSY_2 0x0000'0000 ======================== IPU1-IC ============================== 0x02620000 CONF 0x0001'0000 PRPENC_EN : false PRPENC_CSC1_EN : false PRPENC_ROT_EN : false PRPVF_EN : false PRPVF_CSC1 : false PRPVF_CSC2 : false PRPVF_CMB : false PRPVF_ROT_EN : false PP_EN : true PP_CSC1 : false PP_CSC2 : false PP_CMB : false PP_ROT_EN : false IC_GLB_LOC_A : false IC_KEY_COLOR_EN : false RWS_EN : false CSI_MEM_WR_EN : false 0x02620018 IDMAC_1 0x0040'0024 CB0_BURST_16 : burst 8 px CB1_BURST_16 : burst 8 px CB2_BURST_16 : burst 16 px CB3_BURST_16 : burst 8 px CB4_BURST_16 : burst 8 px CB5_BURST_16 : burst 16 px CB6_BURST_16 : burst 8 px CB7_BURST_16 : burst 8 px ENC_ROT : false ENC_FLIP_LR : false ENC_FLIP_UD : false VF_ROT : false VF_FLIP_LR : false VF_FLIP_UD : false PP_ROT : false PP_FLIP_LR : false PP_FLIP_UD : false ENC_FLIP_RS : false VF_FLIP_RS : false PP_FLIP_RS : true 0x0262001c IDMAC_2 0x07f0'0000 enc_fr_height : 0 vf_fr_height : 0 pp_fr_height : 127 0x02620020 IDMAC_3 0x07f0'0000 enc_fr_width : 0 vf_fr_width : 0 pp_fr_width : 127 ======================== IPU1-CPMEM ============================== 0x027002c0 CH-I#11_0 0x0001fc0f'e0001800'00000000'00000000'00000000 XV : 0 YV : 0 XB : 0 YB : 0 NSB_B : false CF : even SX : 0 SY : 0 NS : 0 SDX : 0 SM : 0 SCC : false SCE : false SDY : 0 SDRX : false SDRY : false BPP : 16 bpp DEC_SEL : 0-15 DIM : 2d SO : progressive BNDM : no bands BM : no block mode ROT : false HFLIP : false VFLIP : false THE : false CAP : false CAE : false FW : 127 FH : 127 EOLI : false 0x027002e0 CH-I#11_1 0x00000000'00003fc0'0103c000'00000000'06027000 EBA0 : 0x06027000 EBA1 : 0x00000000 ILO : 0 NPB : 15 PFS : interleaved 4:2:2 Y1U1Y2V1 ALU : false ALBM : 0 ID : 0 THRESHOLD : 0 SLY : 255 WID0 : 0 WID1 : 0 WID2 : 0 WID3 : 0 OFS0 : 0 OFS1 : 0 OFS2 : 0 OFS3 : 0 SXYS : false CRE : false DEC_SEL2 : false 0x02700580 CH-I#22_0 0x0001fc0f'e1001800'00000000'00000000'00000000 XV : 0 YV : 0 XB : 0 YB : 0 NSB_B : false CF : even SX : 0 SY : 0 NS : 0 SDX : 0 SM : 0 SCC : false SCE : false SDY : 0 SDRX : false SDRY : false BPP : 16 bpp DEC_SEL : 0-15 DIM : 2d SO : progressive BNDM : no bands BM : no block mode ROT : false HFLIP : true VFLIP : false THE : false CAP : false CAE : false FW : 127 FH : 127 EOLI : false 0x027005a0 CH-I#22_1 0x00000000'00003fc0'0103c000'00000000'06039000 EBA0 : 0x06039000 EBA1 : 0x00000000 ILO : 0 NPB : 15 PFS : interleaved 4:2:2 Y1U1Y2V1 ALU : false ALBM : 0 ID : 0 THRESHOLD : 0 SLY : 255 WID0 : 0 WID1 : 0 WID2 : 0 WID3 : 0 OFS0 : 0 OFS1 : 0 OFS2 : 0 OFS3 : 0 SXYS : false CRE : false DEC_SEL2 : false
Solved! Go to Solution.
Kernel driver does not activate IPU-PRG when using only the IC but not a display. PRG must be enabled explicitly.
Nothing has changed since MX6 and MX6q for IPU, I guess you issue could be the dma, you have to try changing channels and see how its working.
