In the IMXRT1050-EVKB board, why did you connect the NC pins (pins #2 and #4) of the 24M crystal PN 7V24000002 to the ground, and didn't you leave it unconnected?
eval board design:
Solved! Go to Solution.
Hello
I hope you are well.
This is to avoid any extra noise that could cause leaving these pins as NC.
If you have more questions do not hesitate to ask me.
Omar
Hello
Omar
thank you
