IMX93 LVDS cann't work
5454ty
HI,
   I am debugging lvds on imx93
   I made my own motherboard
  I am using the dts imx93-11x11-evk-boe-wxga-lvds-panel.dts
  But my lvds of related log is unnormal.
  My log is as follows:
U-Boot SPL 2023.04-dirty (Jun 03 2024 - 21:53:22 -0700)
SOC: 0xa1009300
LC: 0x2040010
PMIC: PCA9451A
PMIC: Over Drive Voltage Mode
DDR: 1866MTS
M33 prepare ok
Normal Boot
Trying to boot from BOOTROM
Boot Stage: Primary boot
image offset 0x8000, pagesize 0x200, ivt offset 0x0
Load image from 0x52400 by ROM_API
NOTICE: BL31: v2.8(release):lf-6.1.55-2.2.0-0-g08e9d4eef
NOTICE: BL31: Built : 06:43:30, Nov 21 2023
U-Boot 2023.04-dirty (Jun 03 2024 - 21:53:22 -0700)
CPU: i.MX93(52) rev1.1 1700 MHz (running at 1692 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 36C
Reset cause: POR (0x1)
Model: NXP i.MX93 11X11 EVK board
DRAM: 2 GiB
tcpc_init: Can't find device id=0x52
setup_typec: tcpc portpd init failed, err=-19
setup_pd_switch: Can't find device id=0x73
TCPC: Vendor ID [0x8008], Product ID [0xa287], Addr [I2C2 0x51]
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port1 init failed, err=-19
pca953x gpio@22: Error reading output register
Core: 225 devices, 36 uclasses, devicetree: separate
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
[*]-Video Link 0adv7535_mipi2hdmi hdmi@3d: Can't find cec device id=0x3c
fail to probe panel device hdmi@3d
fail to get display timings
probe video device failed, ret -19
[0] lcd-controller@4ae30000, video
[1] dsi@4ae10000, video_bridge
[2] hdmi@3d, panel
In: serial
Out: serial
Err: serial
BuildInfo:
- ELE firmware version 0.1.0-44880904
switch to partitions #0, OK
mmc1 is current device
flash target is MMC:1
Net: pca953x gpio@22: Error reading output register
Could not get PHY for FEC0: addr 2
eth1: ethernet@428a0000 [PRIME]
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
Working FDT set to 83000000
mmc0(part 0) is current device
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
Scanning mmc 1:1...
48436 bytes read in 4 ms (11.5 MiB/s)
Unable to open OP-TEE session (err=-5)
mm_communicate failed!
Error: Cannot initialize UEFI sub-system, r = 3
starting USB...
Bus usb@4c100000: Port not available.
Bus usb@4c200000: Port not available.
USB is stopped. Please issue 'usb start' first.
Running BSP bootcmd ...
Failed to load 'boot.scr'
32856576 bytes read in 357 ms (87.8 MiB/s)
Booting from mmc ...
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 0000000083000000, end 000000008300ed33
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.000000] Linux version 6.1.55+g770c5fe2c1d1 (tangyuan@ubuntu) (aarch64-poky-linux-gcc (GCC) 12.3.0, GNU ld (GNU Binutils) 2.40.0.20230703) #19 SMP PREEMPT Mon Jun 24 22:15:38 PDT 2024
[ 0.000000] Machine model: NXP i.MX93 11X11 EVK board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4020000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vdevbuffer@a4020000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4120000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node ele-reserved@a4120000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node ethosu_region@C0000000, compatible id shared-dma-pool
[ 0.000000] earlycon: lpuart32 at MMIO32 0x0000000044380000 (options '')
[ 0.000000] printk: bootconsole [lpuart32] enabled
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xffbd1700-0xffbd3fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000095ffffff]
[ 0.000000] node 0: [mem 0x0000000098000000-0x00000000a3ffffff]
[ 0.000000] node 0: [mem 0x00000000a4000000-0x00000000a421ffff]
[ 0.000000] node 0: [mem 0x00000000a4220000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 20 pages/cpu s44520 r8192 d29208 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 507904
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttyLP0,115200 earlycon root=/dev/mmcblk1p2 rootwait rw
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 1464828K/2064384K available (19776K kernel code, 1622K rwdata, 7236K rodata, 3328K init, 644K bss, 75268K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000048040000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008387] Console: colour dummy device 80x25
[ 0.012641] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.022799] pid_max: default: 32768 minimum: 301
[ 0.027431] LSM: Security Framework initializing
[ 0.032075] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.039354] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.048055] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.054385] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.061382] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.067457] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.074614] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.080802] rcu: Hierarchical SRCU implementation.
[ 0.085446] rcu: Max phase no-delay instances is 1000.
[ 0.091573] EFI services will not be available.
[ 0.096072] smp: Bringing up secondary CPUs ...
[ 0.100783] Detected VIPT I-cache on CPU1
[ 0.100877] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 0.100889] GICv3: CPU1: found redistributor 100 region 0:0x0000000048060000
[ 0.100938] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.101050] smp: Brought up 1 node, 2 CPUs
[ 0.128474] SMP: Total of 2 processors activated.
[ 0.133144] CPU features: detected: 32-bit EL0 Support
[ 0.138266] CPU features: detected: 32-bit EL1 Support
[ 0.143371] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.151944] CPU features: detected: Common not Private translations
[ 0.158184] CPU features: detected: CRC32 instructions
[ 0.163300] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.169017] CPU features: detected: LSE atomic instructions
[ 0.174564] CPU features: detected: Privileged Access Never
[ 0.180110] CPU features: detected: RAS Extension Support
[ 0.185487] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.192473] CPU: All CPU(s) started at EL2
[ 0.196492] alternatives: applying system-wide alternatives
[ 0.207777] devtmpfs: initialized
[ 0.216612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.226127] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.243419] pinctrl core: initialized pinctrl subsystem
[ 0.249955] DMI not present or invalid.
[ 0.254065] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.260718] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.267626] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.275308] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.283200] audit: initializing netlink subsys (disabled)
[ 0.288753] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[ 0.289261] thermal_sys: Registered thermal governor 'step_wise'
[ 0.296233] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.302395] cpuidle: using governor menu
[ 0.312849] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.319420] ASID allocator initialised with 65536 entries
[ 0.325492] Serial: AMBA PL011 UART driver
[ 0.329395] imx mu driver is registered.
[ 0.333233] imx rpmsg driver is registered.
[ 0.343335] imx93-pinctrl 443c0000.pinctrl: initialized IMX pinctrl driver
[ 0.356580] platform 4ae30000.lcd-controller: Fixed dependency cycle(s) with /soc@0/ldb@4ac10020/lvds-channel@0/port@0/endpoint
[ 0.371185] platform lvds_panel: Fixed dependency cycle(s) with /soc@0/ldb@4ac10020/lvds-channel@0/port@1/endpoint
[ 0.381640] KASLR disabled due to lack of seed
[ 0.397569] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.404113] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.410342] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.417100] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.423341] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.430100] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.436341] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.443100] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.451212] ACPI: Interpreter disabled.
[ 0.456087] iommu: Default domain type: Translated
[ 0.460722] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.467217] SCSI subsystem initialized
[ 0.471111] usbcore: registered new interface driver usbfs
[ 0.476366] usbcore: registered new interface driver hub
[ 0.481637] usbcore: registered new device driver usb
[ 0.487611] mc: Linux media interface: v0.10
[ 0.491670] videodev: Linux video capture interface: v2.00
[ 0.497133] pps_core: LinuxPPS API ver. 1 registered
[ 0.502018] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.511124] PTP clock support registered
[ 0.515157] EDAC MC: Ver: 3.0.0
[ 0.519462] FPGA manager framework
[ 0.522681] Advanced Linux Sound Architecture Driver Initialized.
[ 0.529177] Bluetooth: Core ver 2.22
[ 0.532514] NET: Registered PF_BLUETOOTH protocol family
[ 0.537785] Bluetooth: HCI device and connection manager initialized
[ 0.544108] Bluetooth: HCI socket layer initialized
[ 0.548959] Bluetooth: L2CAP socket layer initialized
[ 0.553997] Bluetooth: SCO socket layer initialized
[ 0.559289] vgaarb: loaded
[ 0.562390] clocksource: Switched to clocksource arch_sys_counter
[ 0.568499] VFS: Disk quotas dquot_6.6.0
[ 0.572216] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.579177] pnp: PnP ACPI: disabled
[ 0.587743] NET: Registered PF_INET protocol family
[ 0.592614] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.601013] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.609361] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.617012] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.624953] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.632776] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.639183] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.645745] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.652964] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.658915] RPC: Registered named UNIX socket transport module.
[ 0.664588] RPC: Registered udp transport module.
[ 0.669250] RPC: Registered tcp transport module.
[ 0.673929] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.680974] PCI: CLS 0 bytes, default 64
[ 0.685209] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[ 0.693797] kvm [1]: IPA Size Limit: 40 bits
[ 0.697842] kvm [1]: GICv3: no GICV resource entry
[ 0.702574] kvm [1]: disabling GICv2 emulation
[ 0.707014] kvm [1]: GIC system register CPU interface enabled
[ 0.712863] kvm [1]: vgic interrupt IRQ9
[ 0.716754] kvm [1]: VHE mode initialized successfully
[ 0.722970] Initialise system trusted keyrings
[ 0.727412] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[ 0.738028] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.744172] NFS: Registering the id_resolver key type
[ 0.749013] Key type id_resolver registered
[ 0.753128] Key type id_legacy registered
[ 0.757168] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.763788] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.771182] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.777570] 9p: Installing v9fs 9p2000 file system support
[ 0.808470] Key type asymmetric registered
[ 0.812305] Asymmetric key parser 'x509' registered
[ 0.817207] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.824526] io scheduler mq-deadline registered
[ 0.829030] io scheduler kyber registered
[ 0.838616] EINJ: ACPI disabled.
[ 0.847474] Bus freq driver module loaded
[ 0.857312] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.875158] printk: console [ttyLP0] enabled0x44380010 (irq = 18, base_baud = 1500000) is a FSL_LPUART
[ 0.883557] printk: bootconsole [lpuart32] disabled
[ 0.898569] tangyuan driver inint===============================
[ 0.904606] tangyuan driver init=====================222222222222222222
[ 0.913740] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 0.923189] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.933580] loop: module loaded
[ 0.938349] of_reserved_mem_lookup() returned NULL
[ 0.943337] megasas: 07.719.03.00-rc1
[ 0.953144] tun: Universal TUN/TAP device driver, 1.6
[ 0.959186] thunder_xcv, ver 1.0
[ 0.962479] thunder_bgx, ver 1.0
[ 0.965712] nicpf, ver 1.0
[ 0.969414] pps pps0: new PPS source ptp0
[ 0.975213] mdio_bus 42890000.ethernet-1: MDIO device at address 2 is missing.
[ 0.982939] fec 42890000.ethernet eth0: registered PHC device 0
[ 0.990997] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.998243] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.003740] hclge is initializing
[ 1.007087] e1000: Intel(R) PRO/1000 Network Driver
[ 1.011953] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.017720] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.022674] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.028613] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.034001] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.039613] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.045867] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.052060] sky2: driver version 1.30
[ 1.056361] usbcore: registered new interface driver r8152
[ 1.062243] VFIO - User Level meta-driver version: 0.3
[ 1.071218] usbcore: registered new interface driver uas
[ 1.076605] usbcore: registered new interface driver usb-storage
[ 1.082708] usbcore: registered new interface driver usbserial_generic
[ 1.089242] usbserial: USB Serial support registered for generic
[ 1.095267] usbcore: registered new interface driver ftdi_sio
[ 1.101014] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.108330] usbcore: registered new interface driver usb_serial_simple
[ 1.114902] usbserial: USB Serial support registered for carelink
[ 1.121003] usbserial: USB Serial support registered for flashloader
[ 1.127358] usbserial: USB Serial support registered for funsoft
[ 1.133366] usbserial: USB Serial support registered for google
[ 1.139283] usbserial: USB Serial support registered for hp4x
[ 1.145029] usbserial: USB Serial support registered for kaufmann
[ 1.151122] usbserial: USB Serial support registered for libtransistor
[ 1.157648] usbserial: USB Serial support registered for moto_modem
[ 1.163914] usbserial: USB Serial support registered for motorola_tetra
[ 1.170529] usbserial: USB Serial support registered for nokia
[ 1.176359] usbserial: USB Serial support registered for novatel_gps
[ 1.182712] usbserial: USB Serial support registered for siemens_mpi
[ 1.189073] usbserial: USB Serial support registered for suunto
[ 1.194996] usbserial: USB Serial support registered for vivopay
[ 1.200999] usbserial: USB Serial support registered for zio
[ 1.206676] usbcore: registered new interface driver usb_ehset_test
[ 1.215964] bbnsm_pwrkey 44440000.bbnsm:pwrkey: KEY_POWER without setting in dts
[ 1.224234] input: 44440000.bbnsm:pwrkey as /devices/platform/soc@0/44000000.bus/44440000.bbnsm/44440000.bbnsm:pwrkey/input/input0
[ 1.239236] bbnsm_rtc 44440000.bbnsm:rtc: registered as rtc0
[ 1.245292] bbnsm_rtc 44440000.bbnsm:rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 1.254838] i2c_dev: i2c /dev entries driver
[ 1.262809] imx7ulp-wdt 42490000.wdog: imx93 wdt probe
[ 1.295208] Bluetooth: HCI UART driver ver 2.3
[ 1.299679] Bluetooth: HCI UART protocol H4 registered
[ 1.304808] Bluetooth: HCI UART protocol BCSP registered
[ 1.310137] Bluetooth: HCI UART protocol LL registered
[ 1.315281] Bluetooth: HCI UART protocol ATH3K registered
[ 1.320679] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.327097] Bluetooth: HCI UART protocol Broadcom registered
[ 1.332764] Bluetooth: HCI UART protocol QCA registered
[ 1.339777] sdhci: Secure Digital Host Controller Interface driver
[ 1.346002] sdhci: Copyright(c) Pierre Ossman
[ 1.351008] Synopsys Designware Multimedia Card Interface Driver
[ 1.357575] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.364888] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.372529] fsl-ele-mu soc@0:ele-mu: ele_mu_probe: Not able to read cmd_tag
[ 1.379536] fsl-ele-mu soc@0:ele-mu: ele_mu_probe: Not able to read rsp_tag
[ 1.387084] fsl-ele-mu soc@0:ele-mu: assigned reserved memory node ele-reserved@a4120000
[ 1.395267] fsl-ele-mu soc@0:ele-mu: registering ele-trng
[ 1.396002] mmc0: SDHCI controller on 42850000.mmc [42850000.mmc] using ADMA
[ 1.400958] fsl-ele-mu soc@0:ele-mu: Successfully registered ele-trng
[ 1.414302] random: crng init done
[ 1.414454] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.424616] usbcore: registered new interface driver usbhid
[ 1.430212] usbhid: USB HID core driver
[ 1.436800] ethosu ethosu: assigned reserved memory node ethosu_region@C0000000
[ 1.485244] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.493694] optee: probing for conduit method.
[ 1.498244] optee: revision 4.0 (a303fc80)
[ 1.498832] optee: dynamic shared memory is enabled
[ 1.508140] optee: initialized driver
[ 1.516750] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.516778] NET: Registered PF_LLC protocol family
[ 1.523838] mmcblk0: mmc0:0001 DA6016 14.7 GiB
[ 1.528632] NET: Registered PF_INET6 protocol family
[ 1.538217] mmcblk0boot0: mmc0:0001 DA6016 4.00 MiB
[ 1.538693] Segment Routing with IPv6
[ 1.544427] mmcblk0boot1: mmc0:0001 DA6016 4.00 MiB
[ 1.546961] In-situ OAM (IOAM) with IPv6
[ 1.552857] mmcblk0rpmb: mmc0:0001 DA6016 4.00 MiB, chardev (234:0)
[ 1.555841] NET: Registered PF_PACKET protocol family
[ 1.567141] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.580382] Bluetooth: RFCOMM TTY layer initialized
[ 1.585289] Bluetooth: RFCOMM socket layer initialized
[ 1.590441] Bluetooth: RFCOMM ver 1.11
[ 1.594181] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.599491] Bluetooth: BNEP filters: protocol multicast
[ 1.604713] Bluetooth: BNEP socket layer initialized
[ 1.609666] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.615580] Bluetooth: HIDP socket layer initialized
[ 1.620770] 8021q: 802.1Q VLAN Support v1.8
[ 1.624994] lib80211: common routines for IEEE802.11 drivers
[ 1.630758] 9pnet: Installing 9P2000 support
[ 1.635139] Key type dns_resolver registered
[ 1.639932] registered taskstats version 1
[ 1.644058] Loading compiled-in X.509 certificates
[ 1.665551] usb_phy_generic soc@0:usbphynop1: supply vcc not found, using dummy regulator
[ 1.673888] usb_phy_generic soc@0:usbphynop1: dummy supplies not allowed for exclusive requests
[ 1.682736] usb_phy_generic soc@0:usbphynop2: supply vcc not found, using dummy regulator
[ 1.691022] usb_phy_generic soc@0:usbphynop2: dummy supplies not allowed for exclusive requests
[ 1.710133] imx93-ldb soc@0:ldb@4ac10020: Failed to create device link (0x180) with soc@0:phy@4ac10024
[ 1.724407] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 1.734440] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
[ 1.740630] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[ 1.747445] imx-dwmac 428a0000.ethernet: DWMAC4/5
[ 1.752229] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
[ 1.759349] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
[ 1.766472] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
[ 1.773162] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
[ 1.779312] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.786955] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 1.793729] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 1.800522] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 1.808083] imx-dwmac 428a0000.ethernet: Using 32/32 bits DMA host/device width
[ 1.825140] isi-capture 4ae40000.isi:cap_device: deferring 4ae40000.isi:cap_device device registration
[ 1.834672] mxc-isi 4ae40000.isi: mxc_isi.0 registered successfully
[ 1.843312] remoteproc remoteproc0: imx-rproc is available
[ 1.851999] st_lsm6dsx_i2c 0-006a: supply vdd not found, using dummy regulator
[ 1.859391] st_lsm6dsx_i2c 0-006a: supply vddio not found, using dummy regulator
[ 1.926543] st_lsm6dsx_i2c 0-006a: failed to read whoami register
[ 1.932902] st_lsm6dsx_i2c: probe of 0-006a failed with error -5
[ 1.939340] i2c i2c-0: LPI2C adapter registered
[ 1.945702] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.952463] pca953x 1-0022: using AI
[ 1.956149] pca953x 1-0022: failed writing register
[ 1.961179] pca953x: probe of 1-0022 failed with error -5
[ 1.966955] adp5585 1-0034: Failed to read reg 0x00, ret is -5
[ 1.972793] adp5585: probe of 1-0034 failed with error -5
[ 1.978299] i2c i2c-1: LPI2C adapter registered
[ 1.984053] i2c 2-0050: Fixed dependency cycle(s) with /soc@0/usb@4c100000/port/endpoint
[ 1.992490] tcpci: probe of 2-0050 failed with error -5
[ 1.997934] i2c 2-0051: Fixed dependency cycle(s) with /soc@0/usb@4c200000/port/endpoint
[ 2.007080] adp5585 2-0034: Failed to read reg 0x00, ret is -5
[ 2.012936] adp5585: probe of 2-0034 failed with error -5
[ 2.018565] i2c 2-003c: Fixed dependency cycle(s) with /soc@0/bus@42800000/camera/csi@4ae00000/port@0/endpoint
[ 2.028799] i2c i2c-2: LPI2C adapter registered
[ 2.035551] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.057826] sdhci-esdhc-imx 42860000.mmc: Got CD GPIO
[ 2.059239] dwc-mipi-csi2-host 4ae00000.csi: lanes: 2, name: mxc-mipi-csi2.0
[ 2.072686] OF: graph: no port node found in /soc@0/bus@42000000/i2c@42530000/tcpc@51/connector
[ 2.081434] OF: graph: no port node found in /soc@0/bus@42000000/i2c@42530000/tcpc@51/connector
[ 2.090169] OF: graph: no port node found in /soc@0/bus@42000000/i2c@42530000/tcpc@51/connector
[ 2.103459] mmc1: SDHCI controller on 42860000.mmc [42860000.mmc] using ADMA
[ 2.104466] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.124568] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.138693] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.149224] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.158643] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.165386] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.167265] ALSA device list:
[ 2.174063] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 2.176997] No soundcards found.
[ 2.188478] Waiting for root device /dev/mmcblk1p2...
[ 2.214382] mmc1: host does not support reading read-only switch, assuming write-enable
[ 2.250903] mmc1: new ultra high speed SDR104 SDHC card at address 0001
[ 2.258199] mmcblk1: mmc1:0001 SD16G 14.8 GiB
[ 2.264628] mmcblk1: p1 p2
[ 2.273530] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.559708] EXT4-fs (mmcblk1p2): recovery complete
[ 2.565705] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.574331] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 2.588562] devtmpfs: mounted
[ 2.593025] Freeing unused kernel memory: 3328K
[ 2.597688] Run /sbin/init as init process
[ 2.978156] systemd[1]: System time before build time, advancing clock.
[ 3.068738] systemd[1]: systemd 253.1^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 3.100571] systemd[1]: Detected architecture arm64.
Welcome to NXP i.MX Release Distro 6.1-mickledore (mickledore)!
[ 3.162456] systemd[1]: Hostname set to <imx93evk>.
[ 3.343455] systemd-sysv-generator[190]: SysV service '/etc/init.d/sshd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.370731] systemd-sysv-generator[190]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.397261] systemd-sysv-generator[190]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.421846] systemd-sysv-generator[190]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.449228] systemd-sysv-generator[190]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.473735] systemd-sysv-generator[190]: SysV service '/etc/init.d/trousers' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.498084] systemd-sysv-generator[190]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.523209] systemd-sysv-generator[190]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.548404] systemd-sysv-generator[190]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.573313] systemd-sysv-generator[190]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.598100] systemd-sysv-generator[190]: SysV service '/etc/init.d/fuse' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.623708] systemd-sysv-generator[190]: SysV service '/etc/init.d/rc.local' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.979029] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.031060] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 4.056820] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 4.080782] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 4.104244] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.126956] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 4.150890] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 4.174813] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 4.198610] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 4.218627] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.238620] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 4.258622] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 4.316831] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 4.342729] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 4.363411] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.383039] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 4.407466] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 4.431146] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.455319] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.475669] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.499570] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.523182] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.543209] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 4.590968] systemd[1]: Mounting Huge Pages File System...
[ 4.614973] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.643046] systemd[1]: Mounting Kernel Debug File System...
[ 4.663011] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.681317] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.731306] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.759871] systemd[1]: Starting Load Kernel Module configfs...
[ 4.787699] systemd[1]: Starting Load Kernel Module drm...
[ 4.835336] systemd[1]: Starting Load Kernel Module fuse...
[ 4.856760] fuse: init (API version 7.37)
[ 4.861680] systemd[1]: Starting RPC Bind...
[ 4.878946] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.911492] systemd[1]: Starting Journal Service...
[ 4.961505] systemd[1]: Starting Load Kernel Modules...
[ 4.980395] systemd-journald[204]: Collecting audit messages is enabled.
[ 4.992564] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel command line...
[ 5.039434] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.083526] systemd[1]: Starting Coldplug All udev Devices...
[ 5.085828] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[ 5.115675] systemd[1]: Starting Setup Virtual Console...
[ 5.148936] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 5.159528] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
[ OK ] Finished Setup Virtual Console.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
[ 5.565639] systemd-journald[204]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
[ 5.757519] audit: type=1334 audit(1677836960.776:2): prog-id=5 op=LOAD
[ 5.768102] audit: type=1334 audit(1677836960.784:3): prog-id=6 op=LOAD
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Mounted /var/volatile.
Starting Load/Save OS Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Load/Save OS Random Seed.
[ OK ] Finished Create Volatile Files and Directories.
[ OK ] Started Rule-based Manager for Device Events and Files.
Starting Start Psplash Boot Screen...
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Started Start Psplash Boot Screen.
[ OK ] Started Start psplash-syst…progress communication helper.
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting sshd.socket...
Starting Weston socket...
Starting Console System Startup Logging...
[ OK ] Listening on sshd.socket.
[ OK ] Listening on Weston socket.
[ OK ] Finished Console System Startup Logging.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
Starting D-Bus System Message Bus...
[ OK ] Started Linux Firmware Loader Daemon.
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
Starting Telephony service...
[ OK ] Started Parsec Service.
[ OK ] Started Updates psplash to basic.
Starting LSB: Run /etc/rc.local if it exist...
[ OK ] Started System Logging Service.
Starting User Login Management...
[ OK ] Started TEE Supplicant.
Starting OpenSSH Key Generation...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Started LSB: Run /etc/rc.local if it exist.
[ OK ] Finished OpenSSH Key Generation.
[ OK ] Started Telephony service.
[ OK ] Reached target Preparation for Network.
Starting Connection service...
Starting Network Configuration...
[ OK ] Started User Login Management.
[ OK ] Started Connection service.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started 8.228047] fec 42890000.ethernet eth0: Unable to connect to phy
;39mNetwork Configuration.
[ OK ] Reached target Netwo[ 8.252474] imx-dwmac 428a0000.ethernet eth1: Register MEM_TYPE_PAGE_POOL RxQ-0
rk.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Network Time Service...
[ 8.358991] imx-dwmac 428a0000.ethernet eth1: PHY [stmmac-1:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[ OK ] Started Update psplash to network.
[ 8.386807] imx-dwmac 428a0000.ethernet eth1: No Safety Features support found
[ 8.415088] imx-dwmac 428a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
Starting Terminate Psplash Boot Screen...
Starting[ 8.442612] imx-dwmac 428a0000.ethernet eth1: registered PTP clock
/etc/rc.local Compatibility...
[ 8.466795] imx-dwmac 428a0000.ethernet eth1: FPE workqueue start
[ 8.477160] imx-dwmac 428a0000.ethernet eth1: configuring for phy/rgmii-id link mode
Starting Wait for Network to be Configured...
[ 8.519017] 8021q: adding VLAN 0 to HW filter on device eth1
Starting Permit User Sessions...
[ 8.649529] fec 42890000.ethernet eth0: Unable to connect to phy
[FAILED] Failed to start Terminate Psplash Boot Screen.
See 'systemctl status psplash-quit.service' for details.
[ OK ] Started Network Time Service.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyLP0.
[ OK ] Reached target Login Prompts.
[ 8.954861] audit: type=1334 audit(1677946641.520:6): prog-id=9 op=LOAD
[ 8.967651] audit: type=1334 audit(1677946641.528:7): prog-id=10 op=LOAD
Starting Hostname Service...
Starting Weston, a Wayland…ositor, as a system service...
[ 9.062256] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
Starting WPA supplicant...
[ 9.173745] CAN device driver interface
[ 9.174518] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 9.210697] unregister ISI channel: mxc_isi.0
[ 9.227036] audit: type=1334 audit(1677946641.792:8): prog-id=11 op=LOAD
[ 9.246951] audit: type=1334 audit(1677946641.800:9): prog-id=12 op=LOAD
Starting User Database Manager...
[ 9.315107] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ OK ] Started WPA supplicant.
[ 9.413262] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 9.435558] debugfs: File 'Playback' in directory 'dapm' already present!
[ 9.458486] debugfs: File 'Capture' in directory 'dapm' already present!
[ 9.531137] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 9.580975] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 9.926830] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ OK ] Reached target Hardware activated USB gadget.
[ 9.959666] fsl_mc_err_probe: No ECC DIMMs discovered
[ OK ] Started User Database Manager.
[ OK ] Started Hostname Service.
[ OK ] Created slice User Slice of UID 0.
[ 10.133869] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
Starting User Runtime Directory /run/user/0...
[ 10.202657] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ OK ] Created slice Slice /system/systemd-fsck.
[ OK ] Found device /dev/mmcblk1p1.
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Finished User Runtime Directory /run/user/0.
Starting User Manager for UID 0...
[ 10.690036] audit: type=1006 audit(1677946643.252:10): pid=528 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 10.704778] audit: type=1300 audit(1677946643.252:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff79e11b0 a2=1 a3=1 items=0 ppid=1 pid=528 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 10.770577] kauditd_printk_skb: 1 callbacks suppressed
[ 10.770589] audit: type=1334 audit(1677946643.332:11): prog-id=13 op=LOAD
[ 10.787677] audit: type=1300 audit(1677946643.332:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff7f1e958 a2=90 a3=0 items=0 ppid=1 pid=528 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[ 10.826536] audit: type=1327 audit(1677946643.332:11): proctitle="(systemd)"
[ 10.839086] audit: type=1334 audit(1677946643.348:12): prog-id=13 op=UNLOAD
[ 10.850843] audit: type=1334 audit(1677946643.348:13): prog-id=14 op=LOAD
[ 10.860263] audit: type=1300 audit(1677946643.348:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff7f1ea08 a2=90 a3=aaaabf00204a items=0 ppid=1 pid=528 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[ 10.889542] audit: type=1327 audit(1677946643.348:13): proctitle="(systemd)"
[ 10.902461] audit: type=1334 audit(1677946643.348:14): prog-id=14 op=UNLOAD
[ OK ] Finished File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ OK ] Started User Manager for UID 0.
[ OK ] Started Session c1 of User root.
[ OK ] Mounted /run/media/mmcblk1p1.
Starting Save/Restore Sound Card State...
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ 11.672116] audit: type=1006 audit(1677946644.236:15): pid=448 uid=0 old-auid=4294967295 auid=0 tty=tty7 old-ses=4294967295 ses=2 res=1
[ 11.684376] audit: type=1300 audit(1677946644.236:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff79e11b0 a2=1 a3=1 items=0 ppid=1 pid=448 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[FAILED] Failed to start Weston, a …mpositor, as a system service.
See 'systemctl status weston.service' for details.
NXP i.MX Release Distro 6.1-mickledore imx93evk ttyLP0
imx93evk login:
imx93evk login:
imx93evk login:
imx93evk login: root
root@imx93evk:~# [ 20.369109] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 20.378249] platform usdhc3_pwrseq: deferred probe pending
[ 20.383774] i2c 2-0053: deferred probe pending
[ 20.388232] i2c 0-002a: deferred probe pending
[ 20.392684] i2c 0-001a: deferred probe pending
[ 20.397135] platform regulator-can2-stby: deferred probe pending
[ 20.403141] platform regulator-vdd-12v: deferred probe pending
[ 20.408970] platform regulator-usdhc3: deferred probe pending
[ 20.414716] platform regulator-audio-pwr: deferred probe pending
[ 20.420723] platform regulator-dvdd_sel: deferred probe pending
[ 20.426703] platform regulator-dvdd: deferred probe pending
[ 20.432300] platform regulator-vdd: deferred probe pending
[ 20.437805] platform regulator-vddo: deferred probe pending
[ 20.443382] platform regulator-vaa_sel: deferred probe pending
[ 20.449210] platform regulator-avdd: deferred probe pending
[ 20.454784] i2c 1-0025: deferred probe pending
[ 20.459229] i2c 2-003c: deferred probe pending
[ 20.463675] platform lvds_backlight: deferred probe pending
[ 20.469249] platform imx93-lpm: deferred probe pending
[ 20.474390] platform 42590000.serial: deferred probe pending
[ 20.480047] platform lvds_panel: deferred probe pending
[ 20.485272] platform 425b0000.can: deferred probe pending
[ 20.490674] platform 428b0000.mmc: deferred probe pending
[ 20.496075] platform sound-wm8962: deferred probe pending
[ 20.501472] platform imx-lcdifv3-crtc.0: deferred probe pending
[ 40.110551] kauditd_printk_skb: 1 callbacks suppressed
[ 40.110566] audit: type=1334 audit(1677946672.676:16): prog-id=10 op=UNLOAD
[ 40.122724] audit: type=1334 audit(1677946672.676:17): prog-id=9 op=UNLOAD
root@imx93evk:~#
root@imx93evk:~#
root@imx93evk:~#
root@imx93evk:~#
The critical log is  platform lvds_backlight: deferred probe pending
I have added the log in probe function in the panel-simple.c
The probe function cann't print the log
At first, I thought there was a software issue. Later, I placed the same program on the IMX93 EVK motherboard, and it was able to print the log of this PROBE function normally. So now I'm starting to doubt if it's a hardware issue
Can you help me ?
Rita_Wang
How about your hardware design? The same with NXP reference board?
5454ty
CPU: Industrial temperature grade (-40C to 105C) at 38C
DRAM: 2 GiB
TCPC: Vendor ID [0x33ef], Product ID [0x190c], Addr [I2C2 0x51]
tcpc_clear_alert dm_i2c_write failed, err -110
setup_typec: tcpc port1 init failed, err=-5
Core: 226 devices, 36 uclasses, devicetree: separate
[2] hdmi@3d, panel
In: serial
Out: serial
Err: serial
BuildInfo:
Fastboot: Normal
Normal Boot
Scanning mmc 1:1...
47819 bytes read in 4 ms (11.4 MiB/s)
starting USB...
Bus usb@4c100000: tcpc_init: Polling TCPC POWER STATUS Initialization Status bit failed, ret = -5
tcpc_get_cc_status dm_i2c_read failed, err 3
tcpc_send_command dm_i2c_write failed, err -110
tcpc_send_command dm_i2c_write failed, err 3
Port not available.
Bus usb@4c200000: SRC.Ra only on CC2
tcpc_setup_ufp_mode: Polling ALERT register, TCPC_ALERT_CC_STATUS bit failed, ret = -62
SRC.Ra only on CC2
Port not available.
32856576 bytes read in 1636 ms (19.2 MiB/s)
Using Device Tree in place at 0000000083000000, end 000000008300eaca
Starting kernel ...
[ 0.000000] Linux version 6.1.55+g770c5fe2c1d1 (tangyuan@ubuntu) (aarch64-poky-linux-gcc (GCC) 12.3.0, GNU ld (GNU Binutils) 2.40.0.20230703) #91 SMP PREEMPT Thu Jul 4 03:13:28 PDT 2024
[ 0.000000] NUMA: NODE_DATA [mem 0xffbd2700-0xffbd4fff]
[ 0.000000] Memory: 1464828K/2064384K available (19776K kernel code, 1622K rwdata, 7240K rodata, 3328K init, 644K bss, 75268K reserved, 524288K cma-reserved)
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008381] Console: colour dummy device 80x25
[ 0.012630] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.022791] pid_max: default: 32768 minimum: 301
[ 0.027421] LSM: Security Framework initializing
[ 0.032071] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.039346] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.048029] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.054369] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.061367] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.067442] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.074597] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.080787] rcu: Hierarchical SRCU implementation.
[ 0.085429] rcu: Max phase no-delay instances is 1000.
[ 0.091550] EFI services will not be available.
[ 0.096076] smp: Bringing up secondary CPUs ...
[ 0.100777] Detected VIPT I-cache on CPU1
[ 0.100870] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 0.100882] GICv3: CPU1: found redistributor 100 region 0:0x0000000048060000
[ 0.100931] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.101046] smp: Brought up 1 node, 2 CPUs
[ 0.128475] SMP: Total of 2 processors activated.
[ 0.138267] CPU features: detected: 32-bit EL1 Support
[ 0.151945] CPU features: detected: Common not Private translations
[ 0.174563] CPU features: detected: Privileged Access Never
[ 0.185488] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.192478] CPU: All CPU(s) started at EL2
[ 0.196494] alternatives: applying system-wide alternatives
[ 0.207778] devtmpfs: initialized
[ 0.216484] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.225996] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.243311] pinctrl core: initialized pinctrl subsystem
[ 0.249878] DMI not present or invalid.
[ 0.253994] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.260687] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.267620] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.275306] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.283159] audit: initializing netlink subsys (disabled)
[ 0.288732] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[ 0.289232] thermal_sys: Registered thermal governor 'step_wise'
[ 0.296209] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.302380] cpuidle: using governor menu
[ 0.312825] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.319398] ASID allocator initialised with 65536 entries
[ 0.325467] Serial: AMBA PL011 UART driver
[ 0.329366] imx mu driver is registered.
[ 0.333207] imx rpmsg driver is registered.
[ 0.343121] imx93-pinctrl 443c0000.pinctrl: initialized IMX pinctrl driver
[ 0.356263] platform 4ae30000.lcd-controller: Fixed dependency cycle(s) with /soc@0/ldb@4ac10020/lvds-channel@0/port@0/endpoint
[ 0.370674] platform lvds_panel: Fixed dependency cycle(s) with /soc@0/ldb@4ac10020/lvds-channel@0/port@1/endpoint
[ 0.381088] KASLR disabled due to lack of seed
[ 0.397048] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.403595] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.409822] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.416581] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.422821] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.429580] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.435821] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.442580] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.450750] ACPI: Interpreter disabled.
[ 0.454912] probe 12====================================================
[ 0.461460] probe 12====================================================
[ 0.468216] 5v en is failed================================================
[ 0.474954] lvdsen is failed================================
[ 0.480584] lvdspwr is failed================================
[ 0.486304] lvdspwm is failed================================
[ 0.492024] mipi pwr is failed===========================
[ 0.497456] probe 12====================================================
[ 0.504189] 5v en is failed================================================
[ 0.511007] lvdsen is failed================================
[ 0.516637] lvdspwr is failed================================
[ 0.522357] lvdspwm is failed================================
[ 0.528077] mipi pwr is failed===========================
[ 0.533495] probe 12====================================================
[ 0.540226] 5v en is failed================================================
[ 0.547060] lvdsen is failed================================
[ 0.552691] lvdspwr is failed================================
[ 0.558410] lvdspwm is failed================================
[ 0.564130] mipi pwr is failed===========================
[ 0.569548] probe 12====================================================
[ 0.576236] probe 12====================================================
[ 0.582906] probe 12====================================================
[ 0.589581] probe 12====================================================
[ 0.596739] iommu: Default domain type: Translated
[ 0.601362] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.607859] SCSI subsystem initialized
[ 0.611754] usbcore: registered new interface driver usbfs
[ 0.617012] usbcore: registered new interface driver hub
[ 0.622282] usbcore: registered new device driver usb
[ 0.628217] mc: Linux media interface: v0.10
[ 0.632271] videodev: Linux video capture interface: v2.00
[ 0.637741] pps_core: LinuxPPS API ver. 1 registered
[ 0.642618] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.651724] PTP clock support registered
[ 0.655742] EDAC MC: Ver: 3.0.0
[ 0.660035] FPGA manager framework
[ 0.663251] Advanced Linux Sound Architecture Driver Initialized.
[ 0.669767] Bluetooth: Core ver 2.22
[ 0.673102] NET: Registered PF_BLUETOOTH protocol family
[ 0.678378] Bluetooth: HCI device and connection manager initialized
[ 0.684698] Bluetooth: HCI socket layer initialized
[ 0.689549] Bluetooth: L2CAP socket layer initialized
[ 0.694586] Bluetooth: SCO socket layer initialized
[ 0.699875] vgaarb: loaded
[ 0.702989] clocksource: Switched to clocksource arch_sys_counter
[ 0.709084] VFS: Disk quotas dquot_6.6.0
[ 0.712793] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.719748] pnp: PnP ACPI: disabled
[ 0.728239] NET: Registered PF_INET protocol family
[ 0.733113] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.741512] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.749855] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.757510] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.765449] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.773274] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.779679] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.786242] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.793464] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.799360] RPC: Registered named UNIX socket transport module.
[ 0.805036] RPC: Registered udp transport module.
[ 0.809694] RPC: Registered tcp transport module.
[ 0.814373] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.821428] PCI: CLS 0 bytes, default 64
[ 0.825834] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[ 0.834442] kvm [1]: IPA Size Limit: 40 bits
[ 0.838486] kvm [1]: GICv3: no GICV resource entry
[ 0.843219] kvm [1]: disabling GICv2 emulation
[ 0.847650] kvm [1]: GIC system register CPU interface enabled
[ 0.853498] kvm [1]: vgic interrupt IRQ9
[ 0.857402] kvm [1]: VHE mode initialized successfully
[ 0.863608] Initialise system trusted keyrings
[ 0.868038] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[ 0.878600] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.884786] NFS: Registering the id_resolver key type
[ 0.889644] Key type id_resolver registered
[ 0.893744] Key type id_legacy registered
[ 0.897785] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.904406] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.911789] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.918156] 9p: Installing v9fs 9p2000 file system support
[ 0.949327] Key type asymmetric registered
[ 0.953165] Asymmetric key parser 'x509' registered
[ 0.958061] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.965386] io scheduler mq-deadline registered
[ 0.969889] io scheduler kyber registered
[ 0.976987] led init
[ 0.979148] success
[ 0.983485] EINJ: ACPI disabled.
[ 0.992252] Bus freq driver module loaded
[ 1.001812] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.019603] printk: console [ttyLP0] enabled0x44380010 (irq = 18, base_baud = 1500000) is a FSL_LPUART
[ 1.028007] printk: bootconsole [lpuart32] disabled
[ 1.038479] 42590000.serial: ttyLP4 at MMIO 0x42590010 (irq = 19, base_baud = 1500000) is a FSL_LPUART
[ 1.047905] serial serial0: tty port ttyLP4 registered
[ 1.054327] add by tangyuan imx drm probe=============================
[ 1.064504] add by tangyuan============================panel================
[ 1.071586] LVDS PANEL==============================================
[ 1.077954] panel-simple lvds_panel: supply power not found, using dummy regulator
[ 1.085682] 5v en is failed================================================
[ 1.092634] lvdsen is failed================================
[ 1.098281] lvdspwr is failed================================
[ 1.104017] lvdspwm is failed================================
[ 1.109762] mipi pwr is failed===========================
[ 1.117248] imx drm bind=================================
[ 1.123466] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 1.133008] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.143339] loop: module loaded
[ 1.148107] of_reserved_mem_lookup() returned NULL
[ 1.153095] megasas: 07.719.03.00-rc1
[ 1.162636] tun: Universal TUN/TAP device driver, 1.6
[ 1.168615] thunder_xcv, ver 1.0
[ 1.171924] thunder_bgx, ver 1.0
[ 1.175169] nicpf, ver 1.0
[ 1.178816] pps pps0: new PPS source ptp0
[ 1.183639] fec 42890000.ethernet: Invalid MAC address: 00:00:00:00:00:00
[ 1.190474] fec 42890000.ethernet: Using random MAC address: 8e:c3:64:18:9d:8a
[ 1.198736] mdio_bus 42890000.ethernet-1: MDIO device at address 2 is missing.
[ 1.206446] fec 42890000.ethernet eth0: registered PHC device 0
[ 1.214360] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 1.221610] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.227020] hclge is initializing
[ 1.230351] e1000: Intel(R) PRO/1000 Network Driver
[ 1.235224] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.240998] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.245953] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.251887] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.257280] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.262891] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.269145] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.275324] sky2: driver version 1.30
[ 1.279570] usbcore: registered new interface driver r8152
[ 1.285455] VFIO - User Level meta-driver version: 0.3
[ 1.294303] usbcore: registered new interface driver uas
[ 1.299677] usbcore: registered new interface driver usb-storage
[ 1.305743] usbcore: registered new interface driver usbserial_generic
[ 1.312278] usbserial: USB Serial support registered for generic
[ 1.318325] usbcore: registered new interface driver ftdi_sio
[ 1.324076] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.331393] usbcore: registered new interface driver usb_serial_simple
[ 1.337967] usbserial: USB Serial support registered for carelink
[ 1.344061] usbserial: USB Serial support registered for flashloader
[ 1.350411] usbserial: USB Serial support registered for funsoft
[ 1.356418] usbserial: USB Serial support registered for google
[ 1.362343] usbserial: USB Serial support registered for hp4x
[ 1.368084] usbserial: USB Serial support registered for kaufmann
[ 1.374177] usbserial: USB Serial support registered for libtransistor
[ 1.380705] usbserial: USB Serial support registered for moto_modem
[ 1.386968] usbserial: USB Serial support registered for motorola_tetra
[ 1.393580] usbserial: USB Serial support registered for nokia
[ 1.399417] usbserial: USB Serial support registered for novatel_gps
[ 1.405766] usbserial: USB Serial support registered for siemens_mpi
[ 1.412118] usbserial: USB Serial support registered for suunto
[ 1.418037] usbserial: USB Serial support registered for vivopay
[ 1.424043] usbserial: USB Serial support registered for zio
[ 1.429718] usbcore: registered new interface driver usb_ehset_test
[ 1.438726] bbnsm_pwrkey 44440000.bbnsm:pwrkey: KEY_POWER without setting in dts
[ 1.447027] input: 44440000.bbnsm:pwrkey as /devices/platform/soc@0/44000000.bus/44440000.bbnsm/44440000.bbnsm:pwrkey/input/input0
[ 1.462068] bbnsm_rtc 44440000.bbnsm:rtc: registered as rtc0
[ 1.468141] bbnsm_rtc 44440000.bbnsm:rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 1.477575] i2c_dev: i2c /dev entries driver
[ 1.485372] imx7ulp-wdt 42490000.wdog: imx93 wdt probe
[ 1.516158] Bluetooth: HCI UART driver ver 2.3
[ 1.520645] Bluetooth: HCI UART protocol H4 registered
[ 1.525774] Bluetooth: HCI UART protocol BCSP registered
[ 1.531105] Bluetooth: HCI UART protocol LL registered
[ 1.536234] Bluetooth: HCI UART protocol ATH3K registered
[ 1.541637] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.548080] Bluetooth: HCI UART protocol Broadcom registered
[ 1.553758] Bluetooth: HCI UART protocol QCA registered
[ 1.560789] sdhci: Secure Digital Host Controller Interface driver
[ 1.567017] sdhci: Copyright(c) Pierre Ossman
[ 1.571941] Synopsys Designware Multimedia Card Interface Driver
[ 1.578450] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.586164] sdhci-esdhc-imx 428b0000.mmc: allocated mmc-pwrseq
[ 1.592099] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.599872] fsl-ele-mu soc@0:ele-mu: ele_mu_probe: Not able to read cmd_tag
[ 1.606870] fsl-ele-mu soc@0:ele-mu: ele_mu_probe: Not able to read rsp_tag
[ 1.614544] fsl-ele-mu soc@0:ele-mu: assigned reserved memory node ele-reserved@a4120000
[ 1.622755] fsl-ele-mu soc@0:ele-mu: registering ele-trng
[ 1.623228] mmc2: SDHCI controller on 428b0000.mmc [428b0000.mmc] using ADMA
[ 1.628338] mmc0: SDHCI controller on 42850000.mmc [42850000.mmc] using ADMA
[ 1.642371] random: crng init done
[ 1.642603] fsl-ele-mu soc@0:ele-mu: Successfully registered ele-trng
[ 1.652544] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.659523] usbcore: registered new interface driver usbhid
[ 1.665180] usbhid: USB HID core driver
[ 1.671996] ethosu ethosu: assigned reserved memory node ethosu_region@C0000000
[ 1.720856] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.729874] optee: probing for conduit method.
[ 1.734405] optee: revision 4.0 (a303fc80)
[ 1.735031] optee: dynamic shared memory is enabled
[ 1.744379] optee: initialized driver
[ 1.748632] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.753323] NET: Registered PF_LLC protocol family
[ 1.755771] mmcblk0: mmc0:0001 DA6016 14.7 GiB
[ 1.760609] NET: Registered PF_INET6 protocol family
[ 1.766382] mmcblk0boot0: mmc0:0001 DA6016 4.00 MiB
[ 1.770466] Segment Routing with IPv6
[ 1.775634] mmcblk0boot1: mmc0:0001 DA6016 4.00 MiB
[ 1.778169] In-situ OAM (IOAM) with IPv6
[ 1.784046] mmcblk0rpmb: mmc0:0001 DA6016 4.00 MiB, chardev (511:0)
[ 1.787025] NET: Registered PF_PACKET protocol family
[ 1.798340] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.811543] Bluetooth: RFCOMM TTY layer initialized
[ 1.816456] Bluetooth: RFCOMM socket layer initialized
[ 1.821680] Bluetooth: RFCOMM ver 1.11
[ 1.825485] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.830840] Bluetooth: BNEP filters: protocol multicast
[ 1.836126] Bluetooth: BNEP socket layer initialized
[ 1.841148] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.847117] Bluetooth: HIDP socket layer initialized
[ 1.852320] 8021q: 802.1Q VLAN Support v1.8
[ 1.856613] lib80211: common routines for IEEE802.11 drivers
[ 1.862457] 9pnet: Installing 9P2000 support
[ 1.866875] Key type dns_resolver registered
[ 1.871702] registered taskstats version 1
[ 1.875845] Loading compiled-in X.509 certificates
[ 1.897074] probe 12====================================================
[ 1.905012] probe 12====================================================
[ 1.912827] probe 12====================================================
[ 1.920599] probe 12====================================================
[ 1.928393] probe 12====================================================
[ 1.936281] usb_phy_generic soc@0:usbphynop1: supply vcc not found, using dummy regulator
[ 1.944802] usb_phy_generic soc@0:usbphynop1: dummy supplies not allowed for exclusive requests
[ 1.953839] usb_phy_generic soc@0:usbphynop2: supply vcc not found, using dummy regulator
[ 1.962316] usb_phy_generic soc@0:usbphynop2: dummy supplies not allowed for exclusive requests
[ 1.982218] imx93-ldb soc@0:ldb@4ac10020: Failed to create device link (0x180) with soc@0:phy@4ac10024
[ 1.992638] sdhci-esdhc-imx 428b0000.mmc: Failed to create device link (0x180) with 43820080.gpio
[ 2.002640] add by tangyuan pwm=========================================
[ 2.009438] pwm-backlight lvds_backlight: supply power not found, using dummy regulator
[ 2.017557] of_pwm_get(): can't parse "pwms" property
[ 2.022606] pwm-backlight lvds_backlight: unable to request PWM
[ 2.028520] pwm-backlight: probe of lvds_backlight failed with error -2
[ 2.037911] imx drm bind=================================
[ 2.044012] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.052293] imx-drm display-subsystem: bound soc@0:ldb@4ac10020 (ops imx93_ldb_ops)
[ 2.060390] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.068231] drm fbdev setup====================================================
[ 2.075533] add by tangyuan =========drm fbdev plug===============================
[ 2.083095] fb helper initial config=====================================
[ 2.089981] addby tangyuan fb=====================================
[ 2.111095] add by tangyuan panel bridge enable===================================
[ 2.111107] add by tangyuan for drm_panel_enable=================================
[ 2.431058] 11111111111111111111111111111111111111111111111111111111111
[ 2.431066] tangyuan test for enable=================================================
[ 2.464426] Console: switching to colour frame buffer device 160x50
[ 2.518935] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
[ 2.526552] add by tangyuan =========drm fbdev plug===============================
[ 2.535297] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
[ 2.541160] fb helper hotplug=================================
[ 2.547534] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[ 2.554348] imx-dwmac 428a0000.ethernet: DWMAC4/5
[ 2.559184] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
[ 2.566312] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
[ 2.573433] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
[ 2.580123] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
[ 2.586292] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 2.593943] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 2.600721] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 2.607503] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 2.615061] imx-dwmac 428a0000.ethernet: Using 32/32 bits DMA host/device width
[ 2.630923] isi-capture 4ae40000.isi:cap_device: deferring 4ae40000.isi:cap_device device registration
[ 2.640485] mxc-isi 4ae40000.isi: mxc_isi.0 registered successfully
[ 2.649224] remoteproc remoteproc0: imx-rproc is available
[ 2.656128] probe 12====================================================
[ 2.663889] probe 12====================================================
[ 2.671052] probe 12====================================================
[ 2.678752] probe 12====================================================
[ 2.686434] probe 12====================================================
[ 2.694103] probe 12====================================================
[ 2.703409] st_lsm6dsx_i2c 0-006a: supply vdd not found, using dummy regulator
[ 2.710860] st_lsm6dsx_i2c 0-006a: supply vddio not found, using dummy regulator
[ 2.775042] st_lsm6dsx_i2c 0-006a: failed to read whoami register
[ 2.781416] st_lsm6dsx_i2c: probe of 0-006a failed with error -5
[ 2.787847] i2c i2c-0: LPI2C adapter registered
[ 2.793619] pca9450 probe========================================================
[ 2.801144] nxp-pca9450 1-0025: No IRQ configured?
[ 2.805977] nxp-pca9450: probe of 1-0025 failed with error -22
[ 2.811957] i2c i2c-1: LPI2C adapter registered
[ 2.817726] i2c 2-0050: Fixed dependency cycle(s) with /soc@0/usb@4c100000/port/endpoint
[ 2.826285] tcpci: probe of 2-0050 failed with error -5
[ 2.831705] i2c 2-0051: Fixed dependency cycle(s) with /soc@0/usb@4c200000/port/endpoint
[ 2.840747] i2c 2-003c: Fixed dependency cycle(s) with /soc@0/bus@42800000/camera/csi@4ae00000/port@0/endpoint
[ 2.851090] i2c i2c-2: LPI2C adapter registered
[ 2.868838] sdhci-esdhc-imx 42860000.mmc: Got CD GPIO
[ 2.869483] dwc-mipi-csi2-host 4ae00000.csi: lanes: 2, name: mxc-mipi-csi2.0
[ 2.882425] probe 12====================================================
[ 2.890203] probe 12====================================================
[ 2.897982] probe 12====================================================
[ 2.905733] mmc1: SDHCI controller on 42860000.mmc [42860000.mmc] using ADMA
[ 2.905770] probe 12====================================================
[ 2.920601] probe 12====================================================
[ 2.929385] OF: graph: no port node found in /soc@0/bus@42000000/i2c@42530000/tcpc@51/connector
[ 2.938164] OF: graph: no port node found in /soc@0/bus@42000000/i2c@42530000/tcpc@51/connector
[ 2.946904] OF: graph: no port node found in /soc@0/bus@42000000/i2c@42530000/tcpc@51/connector
[ 2.960652] probe 12====================================================
[ 2.968566] probe 12====================================================
[ 2.976386] probe 12====================================================
[ 2.984286] probe 12====================================================
[ 2.991990] probe 12====================================================
[ 3.001308] probe 12====================================================
[ 3.008971] probe 12====================================================
[ 3.016826] probe 12====================================================
[ 3.024486] probe 12====================================================
[ 3.032343] probe 12====================================================
[ 3.041534] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.051089] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.057771] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.059667] ALSA device list:
[ 3.066445] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 3.069376] No soundcards found.
[ 3.080948] Waiting for root device /dev/mmcblk1p2...
[ 3.220403] mmc1: host does not support reading read-only switch, assuming write-enable
[ 3.230298] mmc1: new high speed SDHC card at address 2105
[ 3.236516] mmcblk1: mmc1:2105 APPSD 7.50 GiB
[ 3.242686] mmcblk1: p1 p2
[ 3.247601] probe 12====================================================
[ 3.255376] probe 12====================================================
[ 3.263086] probe 12====================================================
[ 3.270765] probe 12====================================================
[ 3.278423] probe 12====================================================
[ 3.424151] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 3.432956] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 3.439844] devtmpfs: mounted
[ 3.444507] Freeing unused kernel memory: 3328K
[ 3.449182] Run /sbin/init as init process
[ 4.003020] systemd[1]: System time before build time, advancing clock.
[ 4.114310] systemd[1]: systemd 253.1^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 4.146088] systemd[1]: Detected architecture arm64.
[ 4.215683] systemd[1]: Hostname set to <imx93evk>.
[ 4.371870] systemd-sysv-generator[174]: SysV service '/etc/init.d/rc.local' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.396195] systemd-sysv-generator[174]: SysV service '/etc/init.d/sshd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.420988] systemd-sysv-generator[174]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.447523] systemd-sysv-generator[174]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.471436] systemd-sysv-generator[174]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.495295] systemd-sysv-generator[174]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.519114] systemd-sysv-generator[174]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.547711] systemd-sysv-generator[174]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.576186] systemd-sysv-generator[174]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.604821] systemd-sysv-generator[174]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 4.953568] systemd[1]: Queued start job for default target Graphical Interface.
[ 5.005182] systemd[1]: Created slice Slice /system/getty.
[ 5.029397] systemd[1]: Created slice Slice /system/modprobe.
[ 5.053321] systemd[1]: Created slice Slice /system/serial-getty.
[ 5.076818] systemd[1]: Created slice User and Session Slice.
[ 5.099640] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.123488] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.147439] systemd[1]: Reached target Host and Network Name Lookups.
[ 5.171199] systemd[1]: Reached target Path Units.
[ 5.191227] systemd[1]: Reached target Remote File Systems.
[ 5.211206] systemd[1]: Reached target Slice Units.
[ 5.231237] systemd[1]: Reached target Swaps.
[ 5.294082] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 5.315319] systemd[1]: Reached target RPC Port Mapper.
[ 5.336003] systemd[1]: Listening on Syslog Socket.
[ 5.355684] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.380066] systemd[1]: Listening on Journal Audit Socket.
[ 5.403767] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.427932] systemd[1]: Listening on Journal Socket.
[ 5.448093] systemd[1]: Listening on Network Service Netlink Socket.
[ 5.472058] systemd[1]: Listening on udev Control Socket.
[ 5.495810] systemd[1]: Listening on udev Kernel Socket.
[ 5.528684] systemd[1]: Listening on User Database Manager Socket.
[ 5.575605] systemd[1]: Mounting Huge Pages File System...
[ 5.599908] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.627828] systemd[1]: Mounting Kernel Debug File System...
[ 5.647704] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 5.687695] systemd[1]: Mounting Temporary Directory /tmp...
[ 5.712864] systemd[1]: Starting Create List of Static Device Nodes...
[ 5.740524] systemd[1]: Starting Load Kernel Module configfs...
[ 5.787989] systemd[1]: Starting Load Kernel Module drm...
[ 5.812356] systemd[1]: Starting Load Kernel Module fuse...
[ 5.837842] systemd[1]: Starting RPC Bind...
[ 5.850246] fuse: init (API version 7.37)
[ 5.855685] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 5.875540] systemd[1]: Starting Journal Service...
[ 5.900800] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
[ 5.932913] systemd[1]: Starting Generate network units from Kernel command line...
[ 5.958115] systemd-journald[188]: Collecting audit messages is enabled.
[ 5.970095] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.012227] systemd[1]: Starting Apply Kernel Variables...
[ 6.034971] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[ 6.047966] systemd[1]: Starting Coldplug All udev Devices...
[ 6.092065] systemd[1]: Starting Setup Virtual Console...
[ 6.121995] systemd[1]: Started RPC Bind.
[ 6.140439] systemd[1]: Started Journal Service.
[ 6.501680] systemd-journald[188]: Received client request to flush runtime journal.
[ 6.682338] audit: type=1334 audit(1677836960.676:2): prog-id=5 op=LOAD
[ 6.692331] audit: type=1334 audit(1677836960.684:3): prog-id=6 op=LOAD
[ 8.881210] audit: type=1334 audit(1677840323.100:4): prog-id=7 op=LOAD
[ 8.891802] audit: type=1334 audit(1677840323.108:5): prog-id=8 op=LOAD
[ OK ] Started Network Configuration.
[ OK ] Reached target Netwo[ 9.825055] fec 42890000.ethernet eth0: Unable to connect to phy
rk.
[ 9.883553] imx-dwmac 428a0000.ethernet eth1: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 10.019149] imx-dwmac 428a0000.ethernet eth1: PHY [stmmac-1:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[ 10.055158] imx-dwmac 428a0000.ethernet eth1: No Safety Features support found
Starting /etc/rc.local Compatibility...
[ 10.095193] imx-dwmac 428a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 10.107719] imx-dwmac 428a0000.ethernet eth1: registered PTP clock
[ 10.143617] imx-dwmac 428a0000.ethernet eth1: FPE workqueue start
[ 10.155785] imx-dwmac 428a0000.ethernet eth1: configuring for phy/rgmii-id link mode
[ OK ] Finished Terminate Psplash Boot Screen.
[ 10.211634] 8021q: adding VLAN 0 to HW filter on device eth1
[ OK ] Started Avahi mDNS/DNS-SD Stack.[ 10.257317] fec 42890000.ethernet eth0: Unable to connect to phy
[ 10.427434] audit: type=1334 audit(1677840324.648:6): prog-id=9 op=LOAD
[ 10.437852] audit: type=1334 audit(1677840324.652:7): prog-id=10 op=LOAD
[ OK ] Reached target Multi-User System.
[ 10.651895] audit: type=1334 audit(1677840324.872:8): prog-id=11 op=LOAD
[ 10.675717] audit: type=1334 audit(1677840324.892:9): prog-id=12 op=LOAD
[ 11.072441] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.094574] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 11.107542] unregister ISI channel: mxc_isi.0
[ 11.125907] probe 12====================================================
[ 11.136505] probe 12====================================================
[ 11.147081] probe 12====================================================
[ 11.155224] probe 12====================================================
[ 11.163699] CAN device driver interface
[ 11.172192] probe 12====================================================
[ 11.202483] probe 12====================================================
[ 11.234293] probe 12====================================================
[ 11.257701] probe 12====================================================
[ OK ] Created slice User S[ 11.293623] probe 12====================================================
lice of UID 0.
[ 11.331099] probe 12====================================================
[ 11.486750] audit: type=1006 audit(1677840325.704:10): pid=456 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 11.488829] rtc-pcf2131-i2c 2-0053: pcf2131_probe: watchdog config (wd_ctl) failed
[ 11.500755] audit: type=1300 audit(1677840325.704:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffddad2d10 a2=1 a3=1 items=0 ppid=1 pid=456 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 11.566813] rtc-pcf2131-i2c: probe of 2-0053 failed with error -5
[ 11.719952] fsl_mc_err_probe: No ECC DIMMs discovered
[ 11.750353] input: EETI EXC80H60 Touch Screen as /devices/platform/soc@0/44000000.bus/44340000.i2c/i2c-0/0-002a/input/input1
[ 11.777203] probe 12====================================================
[ 11.804326] probe 12====================================================
[ 11.833800] probe 12====================================================
[ 11.843324] exc3000 0-002a: Retry 1 get EETI EXC3000 model: -151
[ OK ] Created slice Slice[ 11.852539] probe 12====================================================
[ 11.868360] probe 12====================================================
[ 11.896640] exc3000 0-002a: Retry 2 get EETI EXC3000 model: -151
[ 11.931156] exc3000 0-002a: Retry 3 get EETI EXC3000 model: -151
[ 11.957095] probe 12====================================================
[ 11.966287] probe 12====================================================
[ 11.976248] probe 12====================================================
[ 11.985251] probe 12====================================================
[ 11.996558] probe 12====================================================
[ 12.011990] probe 12====================================================
[ 12.259560] exc3000: probe of 0-002a failed with error -151
[ 13.013048] kauditd_printk_skb: 9 callbacks suppressed
[ 13.013064] audit: type=1006 audit(1677840327.232:15): pid=439 uid=0 old-auid=4294967295 auid=0 tty=tty7 old-ses=4294967295 ses=2 res=1
[ 13.033732] audit: type=1300 audit(1677840327.232:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffddad2d10 a2=1 a3=1 items=0 ppid=1 pid=439 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[ 13.059458] audit: type=1327 audit(1677840327.232:15): proctitle="(weston)"
Mounting /run/media/boot-mmcblk1p1...
[ OK ] Mounted /run/media/boot-mmcblk1p1.
imx93evk login:
imx93evk login:
imx93evk login:
imx93evk login:
root@imx93evk:~# gpioinfo
gpiochip0 - 32 lines:
line 0: unnamed input
line 1: unnamed input
line 2: unnamed output consumer=5v_en
line 3: unnamed input
line 4: unnamed input
line 5: unnamed input
line 6: unnamed input
line 7: unnamed input
line 8: unnamed input
line 9: unnamed input
line 10: unnamed input
line 11: unnamed input
line 12: unnamed input
line 13: unnamed input
line 14: unnamed input
line 15: unnamed input
line 16: unnamed input
line 17: unnamed input
line 18: unnamed input
line 19: unnamed input
line 20: unnamed input
line 21: unnamed input
line 22: unnamed input
line 23: unnamed input
line 24: unnamed input
line 25: unnamed input
line 26: unnamed input
line 27: unnamed input
line 28: unnamed input
line 29: unnamed input
line 30: unnamed input
line 31: unnamed input
gpiochip1 - 32 lines:
line 0: unnamed input active-low consumer=cd
line 2: unnamed input
line 7: unnamed output consumer=regulator-usdhc2
line 27: unnamed input consumer=interrupt
gpiochip2 - 32 lines:
gpiochip3 - 32 lines:
line 8: unnamed output consumer=lcd_pwm
line 9: unnamed output consumer=lvds_en
line 11: unnamed output consumer=mipi_pwr
line 13: unnamed output consumer=lvds_pwr
root@imx93evk:~# [ 22.463371] probe 12====================================================
[ 22.471285] probe 12====================================================
[ 22.480150] probe 12====================================================
[ 22.488348] probe 12====================================================
[ 22.498578] probe 12====================================================
[ 22.506349] platform regulator-audio-pwr: deferred probe pending
[ 22.512402] platform regulator-dvdd_sel: deferred probe pending
[ 22.518324] platform regulator-dvdd: deferred probe pending
[ 22.523903] platform 425b0000.can: deferred probe pending
[ 22.529297] platform regulator-vdd: deferred probe pending
[ 22.534782] platform regulator-vddo: deferred probe pending
[ 22.540347] i2c 0-001a: deferred probe pending
[ 22.544793] platform regulator-vaa_sel: deferred probe pending
[ 22.550625] platform regulator-avdd: deferred probe pending
[ 22.556206] i2c 2-003c: deferred probe pending
[ 22.560657] platform imx93-lpm: deferred probe pending
[ 22.565794] platform sound-bt-sco: deferred probe pending
[ 22.571191] platform sound-wm8962: deferred probe pending
[ 22.576591] platform regulator-can2-stby: deferred probe pending
[ 41.127162] audit: type=1334 audit(1677840355.348:16): prog-id=10 op=UNLOAD
[ 41.134183] audit: type=1334 audit(1677840355.348:17): prog-id=9 op=UNLOAD
root@imx93evk:~#
root@imx93evk:~#
The critical log is as follows:
The log is normal?
lvds 看不到图像
