[IMX93] It have no cpufreq directory under sys_fs.
5,035 次查看
takayuki_ishii
Hello community.
I just try to control CPU frequency or governor for i.MX93-EVK.
But it have no cpufreq directory under /sys/devices/system/cpu/cpu0 and cpu1.
I check it both Linux BSP L6.1.1_1.0.0 and L6.1.22_2.0.0.
In Application note AN13917 i.MX 93 Power Consumption Measurement rev0.
It have result both 1.7GHz and 1.4GHz CPU frequency.
So I think it have some method to control cpu frequency.
Other board (i.MX7D-SABRE) with Linux BSP L6.1.22_2.0.0, it can see cpufreq directory.
Does IMX93-EVK not support CPU frequency scaling?
Ishii.
标记 (1)
5,019 次查看
Zhiming_Liu
Hi @takayuki_ishii
i.MX93 doesn't support DVFS, you can switch to nominal mode with below command:
root@imx93evk:~# echo 1 > /sys/devices/platform/imx93-lpm/mode
root@imx93evk:~# mhz
1398 MHz, 0.7153 nanosec clock
root@imx93evk:~#
Best Regards
Zhiming
5 回复数
5,020 次查看
Zhiming_Liu
Hi @takayuki_ishii
root@imx93evk:~#
Best Regards
Zhiming
5,007 次查看
takayuki_ishii
Hello @Zhiming_Liu
thank you for your quick response.
I can change it on my board.
root@imx93-11x11-lpddr4x-evk:~# echo 1 > /sys/devices/platform/imx93-lpm//mode
[13414.223659] System switching to ND mode...
root@imx93-11x11-lpddr4x-evk:~# mhz
root@imx93-11x11-lpddr4x-evk:~# cat /sys/devices/platform/imx93-lpm/mode
System is in ND mode with DDR 1866 MTS!
Ishii.
1,181 次查看
Vladeta_ljubisavljevic
Where one can find this mhz tool?
1,173 次查看
takayuki_ishii
Hello @Vladeta_ljubisavljevic ,
I think that it seems part of lmbench.
~/imx-bsp-6.12.20/build-imx93-14x14-lpddr4x-evk-xwayland/tmp/work/armv8a-poky-linux/lmbench/3.0-a9/lmbench-3.0-a9/src/mhz.c
Ishii.
1,118 次查看
Yes it is in that recipe. Thanks a lot!
%3CLINGO-SUB%20id%3D%22lingo-sub-1706119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BIMX93%5D%20sys_fs%20%E4%B8%8B%E6%B2%A1%E6%9C%89%20cpufreq%20%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1706119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E5%B0%9D%E8%AF%95%E6%8E%A7%E5%88%B6%20i.MX93-EVK%20%E7%9A%84%20CPU%20%E9%A2%91%E7%8E%87%E6%88%96%E8%B0%83%E9%80%9F%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%AE%83%E5%9C%A8%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%20%E5%92%8C%20cpu1%20%E4%B8%8B%E6%B2%A1%E6%9C%89%20cpufreq%20%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%90%8C%E6%97%B6%E6%A3%80%E6%9F%A5%E4%BA%86%20Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20L6.1.1_1.0.0%20%E5%92%8C%20L6.1.22_2.0.0%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20AN13917%20i.MX%2093%20%E5%8A%9F%E8%80%97%E6%B5%8B%E9%87%8F%20rev0%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%83%E7%9A%84%20CPU%20%E9%A2%91%E7%8E%87%E4%B8%BA%201.7GHz%20%E5%92%8C%201.4GHz%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E5%AE%83%E6%9C%89%E6%9F%90%E7%A7%8D%E6%96%B9%E6%B3%95%E6%9D%A5%E6%8E%A7%E5%88%B6%20CPU%20%E9%A2%91%E7%8E%87%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%85%B6%E4%BB%96%E8%A3%85%E6%9C%89%20Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%20L6.1.22_2.0.0%20%E7%9A%84%E6%9D%BF%EF%BC%88i.MX7D-SABRE%EF%BC%89%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%20cpufreq%20%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIMX93-EVK%20%E6%98%AF%E5%90%A6%E4%B8%8D%E6%94%AF%E6%8C%81%20CPU%20%E9%A2%91%E7%8E%87%E7%BC%A9%E6%94%BE%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EIshii.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX93%5D%20It%20have%20no%20cpufreq%20directory%20under%20sys_fs.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%AE%83%E5%9C%A8%E9%82%A3%E4%B8%AA%E9%85%8D%E6%96%B9%E9%87%8C%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX93%5D%20It%20have%20no%20cpufreq%20directory%20under%20sys_fs.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253171%22%20target%3D%22_blank%22%3E%40Vladeta_ljubisavljevic%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%20lmbench%20%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E~%2Fimx-bsp-6.12.20%2Fbuild-imx93-14x14-lpddr4x-evk-xwayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Flmbench%2F3.0-a9%2Flmbench-3.0-a9%2Fsrc%2Fmhz.c%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EIshii.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX93%5D%20It%20have%20no%20cpufreq%20directory%20under%20sys_fs.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E8%BF%99%E7%A7%8D%20mhz%20%E5%B7%A5%E5%85%B7%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1706241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX93%5D%20It%20have%20no%20cpufreq%20directory%20under%20sys_fs.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1706241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%88%91%E7%9A%84%E6%9D%BF%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx93-11x11-lpddr4x-evk%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fdevices%2Fplatform%2Fimx93-lpm%2F%2Fmode%0A%5B13414.223659%5D%20System%20switching%20to%20ND%20mode...%0Aroot%40imx93-11x11-lpddr4x-evk%3A~%23%20mhz%0A1398%20MHz%2C%200.7153%20nanosec%20clock%0Aroot%40imx93-11x11-lpddr4x-evk%3A~%23%20cat%20%2Fsys%2Fdevices%2Fplatform%2Fimx93-lpm%2Fmode%0ASystem%20is%20in%20ND%20mode%20with%20DDR%201866%20MTS!%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EIshii.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1706196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX93%5D%20It%20have%20no%20cpufreq%20directory%20under%20sys_fs.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1706196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F75115%22%20target%3D%22_blank%22%3E%40takayuki_ishii%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Ei.MX93%20%E4%B8%8D%E6%94%AF%E6%8C%81%20DVFS%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%88%87%E6%8D%A2%E5%88%B0%E6%A0%87%E7%A7%B0%E6%A8%A1%E5%BC%8F%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx93evk%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fdevices%2Fplatform%2Fimx93-lpm%2Fmode%0Aroot%40imx93evk%3A~%23%20mhz%0A1398%20MHz%2C%200.7153%20nanosec%20clock%0Aroot%40imx93evk%3A~%23%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%BF%97%E6%98%8E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
