IMX93 A1 can't running bcu
1,917 次查看
Chihyu_Lin
I had IMX93 A1 chip PIMX9352CVVXMAB, and trying to run bcu with our board and got error
"Can't auto recognize the board on location_id=1-1.4.2.1..."
I had tried to run with EVK which is A0  it seems working fine, but our boadrd wasn't. It looks like bcu was not support A1 chip right?eeprom.png
regards,
Julie
标记 (1)
5 回复数
1,876 次查看
Chihyu_Lin
Hi @Manuel_Salas
Thanks for your reply, but I noticed your SOC Info still shown "i.MX93 Rev A0" is that correct? Our board Uboot shonw Rev1.1.
Julie
1,869 次查看
Manuel_Salas
Hello @Chihyu_Lin
I am not pretty sure if BCU is not prepared yet to display A1 SOC revision, but I wanted show to you that A1 and A0 works well in BCU from 1.1.71 version and higher.
Best regards!
Salas.
1,842 次查看
Chihyu_Lin
Hi @Manuel_Salas
Thanks for your clarification.
regards,
Julie
1,899 次查看
Manuel_Salas
Hello @Chihyu_Lin ,
The BCU is supported in both revision, A0 and A1.
I am trying to replicate your issue but unsuccessfully.
Here the logs from my A1 board:
And from A0:
Note at first I am doing a Write eeprom (-w) command and the BCU version I am using is 1.1.71.
Is there any thing that I can do for replicate this issue?
Best regards.
915 次查看
Saravanans1
I am also facing simillar issue, is this issue resolved can anyone provide the steps to resolve the issue?
Saravanan S
