IMX8mini evk cross compile error: cannot find Scrt1.o: No such file or directory
iDave
when I cross-compile my application after setting SDK, below errors occured. How to solve the problem?
Thank you in advance.
/opt/fsl-imx-xwayland/6.1-langdale/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/ gcc/aarch64-poky-linux/12.2.0/ld: missing --end-group; added as last command line option
/opt/fsl-imx-xwayland/6.1-langdale/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/ gcc/aarch64-poky-linux/12.2.0/ld: cannot find Scrt1.o: No such file or directory
/opt/fsl-imx-xwayland/6.1-langdale/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/ gcc/aarch64-poky-linux/12.2.0/ld: cannot find crti.o: No such file or directory
/opt/fsl-imx-xwayland/6.1-langdale/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/ gcc/aarch64-poky-linux/12.2.0/ld: cannot find crtbeginS.o: No such file or directory
Zhiming_Liu
Please make sure you have installed all packages in 3.2 Host packages
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
