IMX8ULP EVK power consumptions
MartinK1
How can get 1.1mW of power consumptions related to video (Sensor Hub Example Based on i.MX 8ULP Applications Processor)? The measured power consumptions of the whole EVK board in PD and DPD mode than is around 200mW. In shut down mode is around 20mW.
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
JorgeCas
Hello, I hope you are doing well.
To get similar measurements, you need to put application domain in PD mode with the next command:
$ echo mem > /sys/power/state
And also, you need to put real time domain on PD mode on console:
Press F and then S.
Best regards.
