IMX8ULP DDR script
IMX8ULP DDR script
3,965 次查看
Maxjay
When I use i.MX8ULP DDR Tool for the step 3: download DDR script, the [ERROR] is show No 'armclk' parameter in DDR script, what's mean for that? Thank you.
4 回复数
3,890 次查看
Maxjay
Sorry for late reply.
The issues is with custom board and EVK is OK, and the different is DDR3 & DDR4, so that is a key for this case?
The RPA file as attachment for your reference, thank you.
3,886 次查看
Manuel_Salas
Hello!
Also, could you please share the Part number of your memory? I can not see it in your RPA file.
If possible, the schematic (related to DDR).
Thank you.
Best regards.
Salas.
3,875 次查看
Maxjay
Hi Sir,
The memory is a Nanya eMCP, the datasheet and related schematic as attachment for your reference, thank you.
3,942 次查看
Manuel_Salas
Hello @Maxjay ,
Could you please share more details?
Are you using the EVK or Custom board?
If possible share your RPA.
Best regards.
Salas.
