IMX8QM MEK GIC ITS configuration in device tree
1,083 次查看
carloscs11
Hello guys,
I am trying to configure the PCIe controller to use MSI interrupts using the ITS component in GIC.
However, there isn't any available device tree configuration of ITS online. I'm using the kernel version 6.6.3.
This is my gic configuration at the moment:
gic:interrupt-controller@51a00000 {
  compatible = "arm,gic-v3";
  reg = <0x00 0x51a00000 0x00 0x10000 0x00 0x51b00000 0x00 0xc0000 0x00 0x52000000 0x00 0x2000 0x00 0x52010000 0x00 0x1000 0x00 0x52020000 0x00 0x20000>;
  #interrupt-cells = <0x03>;
  interrupt-controller;
  interrupts = <0x01 0x09 0x04>;
  interrupt-parent = <&gic>;
  #address-cells = <0x02>;
  #size-cells = <0x02>;
  ranges;
  phandle = <0x01>;
  its@51a20000 {
    reg = <0x00 0x51a20000 0x00 0x20000>;
    phandle = <0x8004>;
    compatible = "arm,gic-v3-its";
    msi-controller;
 And the following warning message is received:
------------[ cut here ]------------␍␊
[09:45:30:076] [ 4.707694] WARNING: CPU: 0 PID: 42 at /drivers/irqchip/irq-gic-v3.c:1744 gic_irq_domain_select+0x148/0x17c␍␊
[09:45:30:092] [ 4.717471] Modules linked in:␍␊
[09:45:30:092] [ 4.720536] CPU: 0 PID: 42 Comm: kworker/u2:2 Not tainted 6.6.3-lts-next-gccf0a99701a7-dirty #1␍␊
[09:45:30:108] [ 4.729252] Hardware name: Freescale i.MX8QM MEK (DT)␍␊
[09:45:30:108] [ 4.734314] Workqueue: events_unbound async_run_entry_fn␍␊
[09:45:30:108] [ 4.739647] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)␍␊
[09:45:30:124] [ 4.746623] pc : gic_irq_domain_select+0x148/0x17c␍␊
[09:45:30:124] [ 4.751425] lr : gic_irq_domain_select+0xb0/0x17c␍␊
[09:45:30:124] [ 4.756142] sp : ffff800082fa3630␍␊
[09:45:30:140] [ 4.759462] x29: ffff800082fa3650 x28: 0000000000000000 x27: 0000000000000000␍␊
[09:45:30:140] [ 4.766622] x26: ffff800082fa3728 x25: ffff0008ff44f910 x24: ffff8000828f1010␍␊
[09:45:30:156] [ 4.773779] x23: ffff0008ff44f8f8 x22: ffff8000816a1ac0 x21: ffff8000816a1ac0␍␊
[09:45:30:156] [ 4.780929] x20: ffff000800020000 x19: ffff800082fa3728 x18: ffffffffffffffff␍␊
[09:45:30:156] [ 4.788079] x17: 6572702066666666 x16: 6666313678302d30 x15: ffff800082fa38a0␍␊
[09:45:30:172] [ 4.795238] x14: ffffffffffffffff x13: 0000000000000000 x12: 0000000000000004␍␊
[09:45:30:172] [ 4.802396] x11: 0101010101010101 x10: fffffffffffb02a0 x9 : 0000000000000005␍␊
[09:45:30:188] [ 4.809555] x8 : ffff800082fa3778 x7 : 0000000000000000 x6 : 070f1900f2f2f5f0␍␊
[09:45:30:188] [ 4.816706] x5 : ffff8000816a1ac0 x4 : 00000000a110c8ee x3 : ffff800082fa363c␍␊
[09:45:30:204] [ 4.823863] x2 : ffff800082fa3640 x1 : ffff800082fa3728 x0 : 00000000ffffffea␍␊
[09:45:30:204] [ 4.831024] Call trace:␍␊
[09:45:30:204] [ 4.833472] gic_irq_domain_select+0x148/0x17c␍␊
[09:45:30:220] [ 4.837929] irq_find_matching_fwspec+0x7c/0x114␍␊
[09:45:30:220] [ 4.842557] irq_create_fwspec_mapping+0x44/0x350␍␊
[09:45:30:220] [ 4.847274] irq_create_of_mapping+0x84/0xb4␍␊
[09:45:30:220] [ 4.851557] of_irq_parse_and_map_pci+0xf4/0x1ec␍␊
[09:45:30:236] [ 4.856188] pci_assign_irq+0x90/0xfc␍␊
[09:45:30:236] [ 4.859862] pci_device_probe+0x50/0x214␍␊
[09:45:30:236] [ 4.863798] really_probe+0x148/0x2b0␍␊
[09:45:30:236] [ 4.867472] __driver_probe_device+0x78/0x12c␍␊
[09:45:30:252] [ 4.871834] driver_probe_device+0xd8/0x15c␍␊
[09:45:30:252] [ 4.876021] __device_attach_driver+0xb8/0x134␍␊
[09:45:30:252] [ 4.880469] bus_for_each_drv+0x88/0xe8␍␊
[09:45:30:252] [ 4.884317] __device_attach+0xa0/0x190␍␊
[09:45:30:268] [ 4.888168] device_attach+0x14/0x20␍␊
[09:45:30:268] [ 4.891753] pci_bus_add_device+0x64/0xd4␍␊
[09:45:30:268] [ 4.895776] pci_bus_add_devices+0x38/0x84␍␊
[09:45:30:268] [ 4.899885] pci_host_probe+0x44/0xbc␍␊
[09:45:30:284] [ 4.903560] dw_pcie_host_init+0x250/0x600␍␊
[09:45:30:284] [ 4.907669] imx6_pcie_probe+0x3c8/0xa58␍␊
[09:45:30:284] [ 4.911605] platform_probe+0x68/0xc8␍␊
[09:45:30:284] [ 4.915279] really_probe+0x148/0x2b0␍␊
[09:45:30:300] [ 4.918947] __driver_probe_device+0x78/0x12c␍␊
[09:45:30:300] [ 4.923316] driver_probe_device+0xd8/0x15c␍␊
[09:45:30:300] [ 4.927503] __device_attach_driver+0xb8/0x134␍␊
[09:45:30:300] [ 4.931960] bus_for_each_drv+0x88/0xe8␍␊
[09:45:30:316] [ 4.935802] __device_attach_async_helper+0xb4/0xd8␍␊
[09:45:30:316] [ 4.940693] async_run_entry_fn+0x34/0xe0␍␊
[09:45:30:316] [ 4.944715] process_one_work+0x138/0x248␍␊
[09:45:30:316] [ 4.948737] worker_thread+0x320/0x438␍␊
[09:45:30:332] [ 4.952501] kthread+0x110/0x114␍␊
[09:45:30:332] [ 4.955739] ret_from_fork+0x10/0x20␍␊
[09:45:30:332] [ 4.959328] ---[ end trace 0000000000000000 ]---␍␊
[09:45:30:332] [ 4.963989] irq: no irq domain found for interrupt-controller@51a00000 !␍␊
I figured out that the problem should be in the ranges property. However I wasn't able to fix it yet.
If anyone could share any device tree configuration working, would be really helpful.
1,062 次查看
carloscs11
Okay I figure it out!
I nedded to change the pcie node's interrupt-map property after adding the ranges property into the gic node.
I followed this configuration and it works fine!
Still, don't get it the logic behind the two zeros after &gic cell.
1,063 次查看
carloscs11
%3CLINGO-SUB%20id%3D%22lingo-sub-1947288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%9A%84%20IMX8QM%20MEK%20GIC%20ITS%20%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20GIC%20%E4%B8%AD%E7%9A%84%20ITS%20%E7%BB%84%E4%BB%B6%E9%85%8D%E7%BD%AE%20PCIe%20%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BB%A5%E4%BD%BF%E7%94%A8%20MSI%20%E4%B8%AD%E6%96%AD%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%E7%BD%91%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84ITS%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E6%98%AF6.6.3%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%20gic%20%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Egic%3Ainterrupt-controller%4051a00000%20%7B%0A%20%20compatible%20%3D%20%22arm%2Cgic-v3%22%3B%0A%20%20reg%20%3D%20%26lt%3B0x00%200x51a00000%200x00%200x10000%200x00%200x51b00000%200x00%200xc0000%200x00%200x52000000%200x00%200x2000%200x00%200x52010000%200x00%200x1000%200x00%200x52020000%200x00%200x20000%26gt%3B%3B%0A%20%20%23interrupt-cells%20%3D%20%26lt%3B0x03%26gt%3B%3B%0A%20%20interrupt-controller%3B%0A%20%20interrupts%20%3D%20%26lt%3B0x01%200x09%200x04%26gt%3B%3B%0A%20%20interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgic%26gt%3B%3B%0A%20%20%23address-cells%20%3D%20%26lt%3B0x02%26gt%3B%3B%0A%20%20%23size-cells%20%3D%20%26lt%3B0x02%26gt%3B%3B%0A%20%20ranges%3B%0A%20%20phandle%20%3D%20%26lt%3B0x01%26gt%3B%3B%0A%20%20its%4051a20000%20%7B%0A%20%20%20%20reg%20%3D%20%26lt%3B0x00%200x51a20000%200x00%200x20000%26gt%3B%3B%0A%20%20%20%20phandle%20%3D%20%26lt%3B0x8004%26gt%3B%3B%0A%20%20%20%20compatible%20%3D%20%22arm%2Cgic-v3-its%22%3B%0A%20%20%20%20msi-controller%3B%0A%20%20%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E5%B9%B6%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%EF%BC%9A%3CBR%20%2F%3E%20------------%5B%20%E4%BB%8E%E6%AD%A4%E5%A4%84%E5%89%AA%E5%BC%80%20%5D------------%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A076%5D%20%5B4.707694%5D%20%E8%AD%A6%E5%91%8A%EF%BC%9ACPU%EF%BC%9A0%20PID%EF%BC%9A42%20%E4%BD%8D%E4%BA%8E%2Fdrivers%2Firqchip%2Firq-gic-v3.c%3A1744%20gic_irq_domain_select%2B0x148%2F0x17c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A092%5D%20%5B%204.717471%5D%20%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%9D%97%EF%BC%9A%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A092%5D%20%5B4.720536%5D%20CPU%EF%BC%9A0%20PID%EF%BC%9A42%20%E9%80%9A%E4%BF%A1%EF%BC%9Akworker%2Fu2%EF%BC%9A2%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%206.6.3-lts-next-gccf0a99701a7-dirty%231%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A108%5D%20%5B%204.729252%5D%20%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AFreescale%20i.MX8QM%20MEK%20(DT)%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A108%5D%20%5B%204.734314%5D%20%E5%B7%A5%E4%BD%9C%E9%98%9F%E5%88%97%EF%BC%9Aevents_unbound%20async_run_entry_fn%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A108%5D%20%5B4.739647%5D%20pstate%3A%2000000005%20(nzcv%20daif%20-PAN%20-UAO%20-TCO%20-DIT%20-SSBS%20BTYPE%3D--)%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A124%5D%20%5B%204.746623%5D%20pc%3A%20gic_irq_domain_select%20%2B%200x148%20%2F%200x17c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A124%5D%20%5B%204.751425%5D%20lr%20%3A%20gic_irq_domain_select%20%2B%200xb0%20%2F%200x17c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A124%5D%20%5B%204.756142%5D%20sp%20%3A%20ffff800082fa3630%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A140%5D%20%5B4.759462%5D%20x29%EF%BC%9Affff800082fa3650%20x28%EF%BC%9A0000000000000000%20x27%EF%BC%9A0000000000000000%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A140%5D%20%5B4.766622%5D%20x26%EF%BC%9Affff800082fa3728%20x25%EF%BC%9Affff0008ff44f910%20x24%EF%BC%9Affff8000828f1010%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A156%5D%20%5B4.773779%5D%20x23%EF%BC%9Affff0008ff44f8f8%20x22%EF%BC%9Affff8000816a1ac0%20x21%EF%BC%9Affff8000816a1ac0%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A156%5D%20%5B%204.780929%5D%20x20%EF%BC%9Affff000800020000%20x19%EF%BC%9Affff800082fa3728%20x18%EF%BC%9Affffffffffffffff%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A156%5D%20%5B4.788079%5D%20x17%EF%BC%9A6572702066666666%20x16%EF%BC%9A6666313678302d30%20x15%EF%BC%9Affff800082fa38a0%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A172%5D%20%5B4.795238%5D%20x14%EF%BC%9Affffffffffffffff%20x13%EF%BC%9A0000000000000000%20x12%EF%BC%9A0000000000000004%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A172%5D%20%5B4.802396%5D%20x11%EF%BC%9A0101010101010101%20x10%EF%BC%9Affffffffffb02a0%20x9%EF%BC%9A0000000000000005%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A188%5D%20%5B4.809555%5D%20x8%EF%BC%9Affff800082fa3778%20x7%EF%BC%9A0000000000000000%20x6%EF%BC%9A070f1900f2f2f5f0%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%EF%BC%9A45%EF%BC%9A30%EF%BC%9A188%5D%20%5B4.816706%5D%20x5%EF%BC%9Affff8000816a1ac0%20x4%EF%BC%9A00000000a110c8ee%20x3%EF%BC%9Affff800082fa363c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A204%5D%20%5B4.823863%5D%20x2%EF%BC%9Affff800082fa3640%20x1%EF%BC%9Affff800082fa3728%20x0%EF%BC%9A00000000ffffffea%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A204%5D%20%5B%204.831024%5D%20%E8%B0%83%E7%94%A8%E8%B7%9F%E8%B8%AA%3A%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A204%5D%20%5B%204.833472%5D%20gic_irq_domain_select%20%2B%200x148%2F0x17c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A220%5D%20%5B%204.837929%5D%20irq_find_matching_fwspec%2B0x7c%2F0x114%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A220%5D%20%5B%204.842557%5D%20irq_create_fwspec_mapping%2B0x44%2F0x350%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A220%5D%20%5B%204.847274%5D%20irq_create_of_mapping%2B0x84%2F0xb4%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A220%5D%20%5B%204.851557%5D%20of_irq_parse_and_map_pci%2B0xf4%2F0x1ec%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A236%5D%20%5B%204.856188%5D%20pci_assign_irq%20%2B%200x90%2F0xfc%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A236%5D%20%5B%204.859862%5D%20pci_device_probe%2B0x50%2F0x214%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A236%5D%20%5B%204.863798%5D%20really_probe%2B0x148%2F0x2b0%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A236%5D%20%5B%204.867472%5D%20__driver_probe_device%2B0x78%2F0x12c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A252%5D%20%5B%204.871834%5D%20driver_probe_device%2B0xd8%2F0x15c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A252%5D%20%5B%204.876021%5D%20__device_attach_driver%2B0xb8%2F0x134%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A252%5D%20%5B%204.880469%5D%20bus_for_each_drv%2B0x88%2F0xe8%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A252%5D%20%5B%204.884317%5D%20__device_attach%2B0xa0%2F0x190%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A268%5D%20%5B%204.888168%5D%E8%AE%BE%E5%A4%87%E8%BF%9E%E6%8E%A5%2B0x14%2F0x20%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A268%5D%20%5B%204.891753%5D%20pci_bus_add_device%2B0x64%2F0xd4%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A268%5D%20%5B%204.895776%5D%20pci_bus_add_devices%2B0x38%2F0x84%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A268%5D%20%5B%204.899885%5D%20pci_host_probe%2B0x44%2F0xbc%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A284%5D%20%5B%204.903560%5D%20dw_pcie_host_init%20%2B%200x250%20%2F%200x600%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A284%5D%20%5B4.907669%5Dimx6_pcie_probe%2B0x3c8%2F0xa58%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A284%5D%20%5B%204.911605%5D%20platform_probe%2B0x68%2F0xc8%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A284%5D%20%5B%204.915279%5D%20really_probe%2B0x148%2F0x2b0%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A300%5D%20%5B%204.918947%5D%20__driver_probe_device%2B0x78%2F0x12c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A300%5D%20%5B%204.923316%5D%20driver_probe_device%2B0xd8%2F0x15c%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A300%5D%20%5B%204.927503%5D%20__device_attach_driver%2B0xb8%2F0x134%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A300%5D%20%5B%204.931960%5D%20bus_for_each_drv%2B0x88%2F0xe8%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A316%5D%20%5B%204.935802%5D%20__device_attach_async_helper%2B0xb4%2F0xd8%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A316%5D%20%5B%204.940693%5D%20async_run_entry_fn%20%2B%200x34%2F0xe0%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A316%5D%20%5B%204.944715%5D%20process_one_work%2B0x138%2F0x248%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A316%5D%20%5B%204.948737%5D%20worker_thread%2B0x320%2F0x438%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A332%5D%20%5B%204.952501%5D%20kthread%2B0x110%2F0x114%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A332%5D%20%5B%204.955739%5D%20ret_from_fork%2B0x10%2F0x20%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A332%5D%20%5B%204.959328%5D%20---%5B%20%E7%BB%93%E6%9D%9F%E8%B7%9F%E8%B8%AA%200000000000000000%5D---%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%20%5B09%3A45%3A30%3A332%5D%20%5B%204.963989%5D%20irq%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0%E4%B8%AD%E6%96%AD%E6%8E%A7%E5%88%B6%E5%99%A8%4051a00000%20%E7%9A%84%20irq%20%E5%9F%9F%EF%BC%81%E2%90%8D%E2%90%8A%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%8F%91%E7%8E%B0%E9%97%AE%E9%A2%98%E5%BA%94%E8%AF%A5%E5%87%BA%E5%9C%A8%20ranges%20%E5%B1%9E%E6%80%A7%E4%B8%8A%E3%80%82%E4%BD%86%E6%98%AF%E6%88%91%E8%BF%98%E6%97%A0%E6%B3%95%E4%BF%AE%E5%A4%8D%E5%AE%83%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%E4%BB%BB%E4%BD%95%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E5%B7%A5%E4%BD%9C%EF%BC%8C%E9%82%A3%E5%B0%86%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1947288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1947444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8QM%20MEK%20GIC%20ITS%20%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E5%B0%86%E8%8C%83%E5%9B%B4%E5%B1%9E%E6%80%A7%E6%B7%BB%E5%8A%A0%E5%88%B0%20gic%20%E8%8A%82%E7%82%B9%E5%90%8E%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%20pcie%20%E8%8A%82%E7%82%B9%E7%9A%84%E4%B8%AD%E6%96%AD%E6%98%A0%E5%B0%84%E5%B1%9E%E6%80%A7%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%BF%99%E4%B8%AA%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Fb586a521770e508d1d440ccb085c7696b9d6d387%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx95.dtsi%23L2804%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E9%85%8D%E7%BD%AE%3C%2FA%3E%EF%BC%8C%E5%AE%83%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E4%B8%8D%E6%98%8E%E7%99%BD%26amp%3Bgic%20%E5%8D%95%E5%85%83%E6%A0%BC%E5%90%8E%E9%9D%A2%E4%B8%A4%E4%B8%AA%E9%9B%B6%E8%83%8C%E5%90%8E%E7%9A%84%E9%80%BB%E8%BE%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
