* DPU clock definition
* Resource Clock Description
* SC_R_DC_0 SC_PM_CLK_MISC0 Display 0 clock
* SC_R_DC_0 SC_PM_CLK_MISC1 Display 1 clock
* SC_R_DC_0_PLL_0 SC_PM_CLK_PLL User programmable PLL clock
* SC_R_DC_0_PLL_1 SC_PM_CLK_PLL User programmable PLL clock
* SC_R_DC_0_VIDEO0 SC_PM_CLK_MISC Bypass 0 clock
* SC_R_DC_0_VIDEO1 SC_PM_CLK_MISC Bypass 1 clock
err = sc_pm_set_resource_power_mode(ipc, DC_RSRC, SC_PM_PW_MODE_ON);
if (SC_ERR_NONE != err)
assert(false);
err = sc_pm_set_resource_power_mode(ipc, DC_PLL_RSRC, SC_PM_PW_MODE_ON);
assert(false);
/* DPU PLL0. */
dpuPllClkFreq_Hz = APP_PIXEL_CLOCK_HZ * 8;
err = sc_pm_set_clock_rate(ipc, DC_PLL_RSRC, SC_PM_CLK_PLL, &dpuPllClkFreq_Hz);
assert(false);
err = sc_pm_clock_enable(ipc, DC_PLL_RSRC, SC_PM_CLK_PLL, true, false);
assert(false);
Failure to debug will result in the assert(false) function
(1) The M40 of IMX8QM does not support DPU operation.
(2) Is DPU configuration required in SCFW
1) dpu can support M4 core0:
2) for DPU driver, you can find:
"https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/gpu/imx/dpu?h=imx_5.4.70_2.3.0"
