IMX8MQ chip achieves dual screen differential display
ximenbingmeng
The kernel version we are using is kernel5.10.72;
a. Can a QT software drag from an HDMI screen to a MIPI screen to achieve similar expansion functions, as the display needs to go through a GPU?
b. What are the restrictions on MIPI screens not being able to play videos? Does it mean that videos cannot be played through the GST command hardware?
Looking forward to your reply, thank you very much!
Zhiming_Liu
a: The BSP can't support it on i.MX8MQ
b: You can use GST to play video.
Best Regards
Zhiming
