Hi All,
This is critical issue. Has any faced such issue before? Any suggestion or pointer related to this issue will be appreciated.
Jemish
Hi @Chavira
Thanks for information, we will take it from here.
We can close this discussion.
Jemish
Hi Chavira,
We are using AX88179_178A usb to Ethernet adapter.
Jemish
Hi @jemish_1990 !
Thank you for contacting NXP Support!
Sorry, I cannot reproduce the error on our evk.
Try to see if is any bridge configured, and check and compare your schematic with the evk schematic.
Sorry for the mistake!
Best Regards!
Chavira
Hi @jemish_1990 !
What adapter are you using?
I will try to reproduce the error on a evk board.
I know that is not the same, but I can try.
Best Regards!
Chavira
