Hello All,
On my IMX8MQ-EVK I am using "U-Boot 2019.04" from git://source.codeaurora.org/external/imx/uboot-imx.git branch:-imx_v2019.04_4.19.35_1.1.0"
Need "distro_bootcmd" support for my work and found that it is not supported by default,
hence back-porting upstream patches https://lists.denx.de/pipermail/u-boot/2020-December/435286.html
queries
1. is there any specific reason till now no support added for "distro_bootcmd" for U-Boot 2019.04"?
2. also while back-porting above "distro_bootcmd" patch on "U-Boot 2019.04" observed I needed to explicitly comment-out the the check for disabled SPL_BUILD (#ifndef CONFIG_SPL_BUILD)"
without this u-boot build breaks , tried disabling SPL configs and un-defining (#undef CONFIG_SPL_BUILD) n source but won't help much.
+/*#ifndef CONFIG_SPL_BUILD*/
+#define BOOT_TARGET_DEVICES(func) \
+ func(MMC, mmc, 0) \
+ func(MMC, mmc, 1) \
+ func(DHCP, dhcp, na)
+#include <config_distro_bootcmd.h>
+/*#endif*/
so commenting out "#ifndef CONFIG_SPL_BUILD" for "U-Boot 2019.04" will be fine? Or
Please advise if I am missing anything while enabling distro_bootcmd support on "U-Boot 2019.04"
Shrikant Bobade
解決済! 解決策の投稿を見る。
Hi Shrikant
"U-Boot 2019.04" is more than year old and unfortunately not more supported, recommended to
use latest uboot releases described on
For support with backporting may be recommended to post issue on uboot mail list
https://lists.denx.de/listinfo/u-boot
also NXP has special service for help with backporting, NXP Professional Services:
https://contact.nxp.com/new-prof-svcs-sw-tech
this is defined by NXP software management, for additional details suggest to contact
local office.
Hi Igor,
Thanks for your response and information.
Shrikant
Hi Shrikant
local office.
