Hi Support,
When I using external clock(EXT3) as micfil's root clock, the frequency is 12.288Mhz, ORS set 8, clock div is 4, the clock after frequency division meets the requirements of mic array sensor, we found data loss when the PDM sampling rate is 48k and channel=8.
But 48k & channel=4 or 16K & channel=8 is OK.
Since the external clock frequency cannot be changed, how can micfil be configured for 48K & 8 channel audio sampling?
Solved! Go to Solution.
Hi @ZenJeams
For 48k, 8ch, div=4, the div cannot meet the requirement of Minumum Required CLKDIV.
The minimum required CLKDIV value in Very Low Quality mode is:
floor(K*CLKDIV) >= K * (10+43EC) / (8*OSR) = 5.53.
We recognized you actually only need 4channels instead of 8. But the channels number you need are ch0, ch2, ch4 and ch6, they are among the 8channels.
I have made a patch to extract only the channels you need, please have a try and let me know the result.
Hi @ZenJeams
Good (y)
