[IMX8MP] caam.jr and memory leak problems will occur when writing files to encrypted storage
ZongYue
When I use 8MPLUS-BB EVM with Yocto SDK imx-5.15.71-2.2.2 to do encrypted storage testing, it will happen below error:
[  599.799860] caam_jr 30902000.jr: unable to map source
[  599.799860] caam_jr 30902000.jr: unable to map destination
[  599.799856] swiotlb_tbl_map_single: 29 callbacks suppressed
[  599.799871] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32766 (slots)
[  599.807733] sdhci-esdhc-imx 30b60000.mmc: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32747 (slots)
[  599.810472] caam_jr 30902000.jr: unable to map destination
[  599.811862] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[  599.811875] caam_jr 30902000.jr: unable to map destination
[  599.817845] sdhci-esdhc-imx 30b60000.mmc: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32716 (slots)
[  599.825010] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[  599.825028] caam_jr 30902000.jr: unable to map destination
[  599.829011] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32739 (slots)
[  599.830025] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[  599.830037] caam_jr 30902000.jr: unable to map source
[  599.830473] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[  599.830480] caam_jr 30902000.jr: unable to map destination
[  599.832220] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[  599.832243] caam_jr 30902000.jr: unable to map source
[  599.832297] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[  599.832303] caam_jr 30902000.jr: unable to map source
[  599.956856] caam_jr 30902000.jr: unable to map source
[  600.020029] EXT4-fs warning: 2 callbacks suppressed
[  600.020043] EXT4-fs warning (device dm-0): ext4_end_bio:344: I/O error 10 writing to inode 12 starting block 254977)
[  600.035480] buffer_io_error: 24566 callbacks suppressed
[  600.035486] Buffer I/O error on device dm-0, logical block 253953
[  600.046797] Buffer I/O error on device dm-0, logical block 253954
[  600.052887] Buffer I/O error on device dm-0, logical block 253955
[  600.058976] Buffer I/O error on device dm-0, logical block 253956
[  600.065091] Buffer I/O error on device dm-0, logical block 253957
[  600.071183] Buffer I/O error on device dm-0, logical block 253958
[  600.077274] Buffer I/O error on device dm-0, logical block 253959
[  600.083364] Buffer I/O error on device dm-0, logical block 253960
[  600.089475] Buffer I/O error on device dm-0, logical block 253961
[  600.095569] Buffer I/O error on device dm-0, logical block 253962
[  600.113708] EXT4-fs warning (device dm-0): ext4_end_bio:344: I/O error 10 writing to inode 12 starting block 259073)
[  600.126834] EXT4-fs warning (device dm-0): ext4_end_bio:344: I/O error 10 writing to inode 12 starting block 257025)
[  600.139537] EXT4-fs warning (device dm-0): ext4_end_bio:344: I/O error 10 writing to inode 12 starting block 80897)
[  600.151162] EXT4-fs warning (device dm-0): ext4_end_bio:344: I/O error 10 writing to inode 12 starting block 78849)
[  600.185542] EXT4-fs warning (device dm-0): ext4_end_bio:344: I/O error 10 writing to inode 12 starting block 76801)
[  600.197689] JBD2: Detected IO errors while flushing file data on dm-0-8
 And system memory will leak.
I put the test log as attachment.
Wondering if there are any limitations to using encrypted storage feature?
Harvey021
This should be a known issue, suggest to test with newer BSP, l just get a chance of testing the same with BSP 6.6.3 and without such issue.
Also you can have a reference for the BSP 5.15 with this link
Harvey
Harvey021
Harvey
ZongYue
Hi @Harvey021 ,
Thank you,  I will update with any news soon.
I would also like to ask if CAAM is suitable for situations where there is only 1GB of RAM.
From the article, most of them use more than 2GB of RAM.
Harvey021
Hi @ZongYue
I'm not sure about the correlation.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2020457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BIMX8MP%5D%20caam.jr%20and%20memory%20leak%20problems%20will%20occur%20when%20writing%20files%20to%20encrypted%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EWhen%20I%20use%208MPLUS-BB%20EVM%20with%20Yocto%20SDK%20imx-5.15.71-2.2.2%20to%20do%20encrypted%20storage%20testing%2C%20it%20will%20happen%20below%20error%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%5B%20%20599.799860%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20source%0A%5B%20%20599.799860%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20destination%0A%5B%20%20599.799856%5D%20swiotlb_tbl_map_single%3A%2029%20callbacks%20suppressed%0A%5B%20%20599.799871%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032766%20(slots)%0A%5B%20%20599.807733%5D%20sdhci-esdhc-imx%2030b60000.mmc%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%204096%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032747%20(slots)%0A%5B%20%20599.810472%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20destination%0A%5B%20%20599.811862%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032768%20(slots)%0A%5B%20%20599.811875%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20destination%0A%5B%20%20599.817845%5D%20sdhci-esdhc-imx%2030b60000.mmc%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%204096%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032716%20(slots)%0A%5B%20%20599.825010%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032768%20(slots)%0A%5B%20%20599.825028%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20destination%0A%5B%20%20599.829011%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032739%20(slots)%0A%5B%20%20599.830025%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032768%20(slots)%0A%5B%20%20599.830037%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20source%0A%5B%20%20599.830473%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032768%20(slots)%0A%5B%20%20599.830480%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20destination%0A%5B%20%20599.832220%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032768%20(slots)%0A%5B%20%20599.832243%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20source%0A%5B%20%20599.832297%5D%20caam_jr%2030902000.jr%3A%20swiotlb%20buffer%20is%20full%20(sz%3A%20512%20bytes)%2C%20total%2032768%20(slots)%2C%20used%2032768%20(slots)%0A%5B%20%20599.832303%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20source%0A%5B%20%20599.956856%5D%20caam_jr%2030902000.jr%3A%20unable%20to%20map%20source%0A%5B%20%20600.020029%5D%20EXT4-fs%20warning%3A%202%20callbacks%20suppressed%0A%5B%20%20600.020043%5D%20EXT4-fs%20warning%20(device%20dm-0)%3A%20ext4_end_bio%3A344%3A%20I%2FO%20error%2010%20writing%20to%20inode%2012%20starting%20block%20254977)%0A%5B%20%20600.035480%5D%20buffer_io_error%3A%2024566%20callbacks%20suppressed%0A%5B%20%20600.035486%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253953%0A%5B%20%20600.046797%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253954%0A%5B%20%20600.052887%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253955%0A%5B%20%20600.058976%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253956%0A%5B%20%20600.065091%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253957%0A%5B%20%20600.071183%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253958%0A%5B%20%20600.077274%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253959%0A%5B%20%20600.083364%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253960%0A%5B%20%20600.089475%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253961%0A%5B%20%20600.095569%5D%20Buffer%20I%2FO%20error%20on%20device%20dm-0%2C%20logical%20block%20253962%0A%5B%20%20600.113708%5D%20EXT4-fs%20warning%20(device%20dm-0)%3A%20ext4_end_bio%3A344%3A%20I%2FO%20error%2010%20writing%20to%20inode%2012%20starting%20block%20259073)%0A%5B%20%20600.126834%5D%20EXT4-fs%20warning%20(device%20dm-0)%3A%20ext4_end_bio%3A344%3A%20I%2FO%20error%2010%20writing%20to%20inode%2012%20starting%20block%20257025)%0A%5B%20%20600.139537%5D%20EXT4-fs%20warning%20(device%20dm-0)%3A%20ext4_end_bio%3A344%3A%20I%2FO%20error%2010%20writing%20to%20inode%2012%20starting%20block%2080897)%0A%5B%20%20600.151162%5D%20EXT4-fs%20warning%20(device%20dm-0)%3A%20ext4_end_bio%3A344%3A%20I%2FO%20error%2010%20writing%20to%20inode%2012%20starting%20block%2078849)%0A%5B%20%20600.185542%5D%20EXT4-fs%20warning%20(device%20dm-0)%3A%20ext4_end_bio%3A344%3A%20I%2FO%20error%2010%20writing%20to%20inode%2012%20starting%20block%2076801)%0A%5B%20%20600.197689%5D%20JBD2%3A%20Detected%20IO%20errors%20while%20flushing%20file%20data%20on%20dm-0-8%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3BAnd%20system%20memory%20will%20leak.%3C%2FP%3E%3CP%3EI%20put%20the%20test%20log%20as%20attachment.%3C%2FP%3E%3CP%3EWondering%20if%20there%20are%20any%20limitations%20to%20using%20encrypted%20storage%20feature%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2020457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%5BIMX8MP%5D%20caam.jr%20and%20memory%20leak%20problems%20will%20occur%20when%20writing%20files%20to%20encrypted%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F221888%22%20target%3D%22_blank%22%3E%40ZongYue%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI'm%20not%20sure%20about%20the%20correlation.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%5BIMX8MP%5D%20caam.jr%20and%20memory%20leak%20problems%20will%20occur%20when%20writing%20files%20to%20encrypted%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192970%22%20target%3D%22_blank%22%3E%40Harvey021%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%3CSPAN%3EThank%20you%2C%26nbsp%3B%20I%20will%20update%20with%20any%20news%20soon.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20would%20also%20like%20to%20ask%20if%20CAAM%20is%20suitable%20for%20situations%20where%20there%20is%20only%201GB%20of%20RAM.%3CBR%20%2F%3EFrom%20the%20article%2C%20most%20of%20them%20use%20more%20than%202GB%20of%20RAM.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%5BIMX8MP%5D%20caam.jr%20and%20memory%20leak%20problems%20will%20occur%20when%20writing%20files%20to%20encrypted%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThis%20should%20be%20a%20known%20issue%2C%20suggest%20to%20test%20with%20newer%20BSP%2C%20l%20just%20get%20a%20chance%20of%20testing%20the%20same%20with%20BSP%206.6.3%20and%20without%20such%20issue.%3C%2FP%3E%0A%3CP%3EAlso%20you%20can%20have%20a%20reference%20for%20the%20BSP%205.15%20with%20this%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fquot-swiotlb-buffer-is-full-quot-when-writing-large-file-on%2Fm-p%2F1586218%22%20target%3D%22_self%22%3Elink%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
