IMX8MP SOM nor flash connection
710 次查看
Majidbahmani
Hope you are well.
I want to read/write data from Flash Nor in IMX8MP SOM. In schematic I only found that "Nor Flash" is connected through QSPIA (Page 2). However, QSPIA has two channels, and I couldn't find any information in the schematic which channel is used. Furthermore, "Nor Flash" has a reset pin which pin of IMX8MP has been connected to the rest pin?
Nor Flash Pins:
Majid
694 次查看
Chavira
Hi @Majidbahmani!
Thank you for contacting NXP Support!
You can refer to the som schematic.
https://www.nxp.com/webapp/Download?colCode=8MPLUSLPD4-CPU
Best regards!
Chavira
