IMX8MP NXP-Desktop failed to compile sdk
707 次查看
ace12
bitbake imx-image-desktop -c populate_sdk gets an error when it compiles to pseudo. When compiling the filesystem, pseudo-native compiles without errors. I don't know what the problem is.
5 回复数
680 次查看
Chavira
Hi @ace12!
Thank you for contacting NXP Support!
Try to clean the compilation of pseudo using the command " bitbake -c clean pseudo " and try to compile the SDK again.
If the problem persists, try to update your packages using " sudo apt update " and " sudo apt upgrade ".
Ensure that you have all the packages needed to compile.
Essential Yocto Project host packages are:
$ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential \
chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils \
iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev \
python3-subunit mesa-common-dev zstd liblz4-tool file locales -y
$ sudo locale-gen en_US.UTF-8
I compiled pseudo without errors, check the log attached
Best Regards!
Chavira
673 次查看
ace12
I'm sorry, but it still fails after I try. I want to ask, my environment is Ubuntu18.04, is it caused by the environment problem
670 次查看
Chavira
Hi @ace12!
The recommended minimum Ubuntu version is 20.04 or later.
Please check chapter 3 of our Yocto User Guide.
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
Best Regards!
Chavira
660 次查看
ace12
Or, what can I do to skip compiling pseudo?
665 次查看
ace12
Sorry, I tried Ubuntu22.04, but it still gave an error, and I have updated the environment according to all the commands you gave. Below is the log of the error record
