IMX8MP-EVK Screen Timeout issue
1,618件の閲覧回数
Shanga
Hi NXP,
Android 13 (imx-android-13.0.0_1.2.0) with IMX8MP , we are setting time 5 seconds for Screen timeout  in setting
expected behaviour after 5 second of screen inactivity Display should time out
but Screen is not turned off after the duration
Please share your input how to achieve screen time out.
IMX8MPLUS
タグ(2)
2 返答(返信)
1,594件の閲覧回数
Bio_TICFSL
To adjust the screen timeout please use the given below command.
adb shell settings put system screen_off_timeout <time_in_ms>
After setting the value please check via the below-given command.
adb shell settings get system screen_off_timeout
1,570件の閲覧回数
Shanga
Hi ,
We tried to set it as directed,we notice only a slight dim of the display brightness.Rather than getting it done through adb shell ,Is it possible to perform this successfully from the UI.
