IMX8MN unable to get DRM/FB working
402 次查看
AyrtonL
I am unable to get an IMX8MN working with a display.
I am using upstream Linux kernel 6.9.
I suspect my DTS is ok.
But some Kernel config might be missing.
Some help is much appreciated
I would expect my linux at least has some kind of "fb*" or "/drm/card*" entry.
But nothing.
I already activated the LCDIF config, same goes for the DRM and DRM_ETNAVIV.
Unfortunate, I am unable to find anything about it in the TRM.
Please see the attached defconfig and decompiled DTB (since dtbs can not be uploaded).
1 回复
379 次查看
Bio_TICFSL
The Mx8MNano support up to 1080p60 display through MIPI DSI, please check the EVK, the default dtb is working correctly.
regards
