We have some questions about IOMUX for imx8mn. I thought we could use the pinctrl group which has PINs from different PAD/ALT groups. Just like the following device tree. Combined the multiplexed pins from ENET, GPIO, and SD PAD.
I am correct here?
If yes, does this kind of configuration method apply to all other peripheral devices? For instance, UART:
Combining SD1 Pad and Uart2 PAD in pinctrl_uart2 together.
Thanks for your time and help.
Solved! Go to Solution.
Hi Jie
yes this understanding is correct, applicable to all modules (other peripheral devices).
Hi Jie
