[IMX8MMINILPD4-EVK - Bluetooth] How to transfer files between BLE devices?
2,081件の閲覧回数
expman99
I am new to bluetooth field. I would like to use imx8mm as a BLE device that can play GATT server role for file transferring with smartphone and pc.
I found Object Transfer Profile and  Object Transfer Service profiles on https://www.bluetooth.com/specifications/gatt/ but I do not know how to use them with imx8mm.
Anyone can help me the way to use them or other profiles or custom profile code example for this problem?
Thank you,
2 返答(返信)
1,830件の閲覧回数
expman99
Thank Kunal Kotecha,
I use the EVK as BLE device, not classic device. I solved my problem.
1,830件の閲覧回数
kunalkotecha1
Senior Contributor II
Hi expman99@gmail.com,
I assume you are using i.MX8M Mini EVK. I have tested the bluetooth on this evk and connected the same with smartphone. For doing the same you can refer the attached "i.MX_Linux_User's_Guide.pdf", section 10.1.
Also, for various bluetooth services and operations, you can use the utility like bluetoothctl or obexftp for file transfer.
Kunal
