IMX8MM how to playback 24bit I2S with SAI
Brady
Please help me, i am blocked on I2S 24bit playback with SAI.
I  can say 16bit and 32bit no problem, and I try to playback 24bit via 32bit format shift 8 bits, then i have probelms. I think the confirguration should be based on there.
and the register could be "SAI Transmit Configuration 5 Register (TCR5)"
Then I try to change the fsl_sai.c, unfortunately do not work, the LRCLK and data gone if i change slot width to 32 and word_width to 7 or 31.
    val_cr5 |= FSL_SAI_CR5_WNW(slot_width);
    val_cr5 |= FSL_SAI_CR5_W0W(slot_width);
    if (sai->is_lsb_first || sai->is_dsd)
        val_cr5 |= FSL_SAI_CR5_FBT(0);
    else
        val_cr5 |= FSL_SAI_CR5_FBT(word_width - 1);
Please help me on how to configure 8 bit shift to support 24bit.
big big big thanks.
ThKe93
Don't know if this topic is still active, but I had a similar issue and could solve it by changing fsl_sai.c (W0W and SYWD)
https://community.nxp.com/t5/i-MX-Processors/Integrating-audio-codec-MAX98089-on-i-MX8M-Plus/td-p/16...
Thomas
