Please help me, i am blocked on I2S 24bit playback with SAI.
I can say 16bit and 32bit no problem, and I try to playback 24bit via 32bit format shift 8 bits, then i have probelms. I think the confirguration should be based on there.
and the register could be "SAI Transmit Configuration 5 Register (TCR5)"
Then I try to change the fsl_sai.c, unfortunately do not work, the LRCLK and data gone if i change slot width to 32 and word_width to 7 or 31.
Please help me on how to configure 8 bit shift to support 24bit.
big big big thanks.
Don't know if this topic is still active, but I had a similar issue and could solve it by changing fsl_sai.c (W0W and SYWD)
Thomas
