IMX8MM Need to recompile BUSYBOX
1,369 次查看
xfg
Hi.Now,I have a toolchain and sdk file.Need to recompile busybox for chinese.Use to yocto build file,It consumes a lot of hard drive and time.manual complilde busybox nonsupport imx8mm, whether good idea.(busybox 1.27.2)
2 回复数
1,362 次查看
weidong_sun
   busybox的编译方法,你可以参考网上的方法,网上分享的方法有很多,比如这个:
https://blog.csdn.net/u011774239/article/details/50916288
   但是,编译工具链最好使用NXP提供的。
1. 根据i.MX_Linux_Users_Guide.pdf中的standalone一章,讲解的方法导出 toolchain. 并安装到/opt目录中。
standalone一章是:How to build U-Boot and Kernel in standalone environment
2. 编译前,指定工具链和CPU架构,下面是个例子:
# source /opt/fsl-imx-xwayland//environment-setup-aarch64-poky-linux
# export ARCH=arm64
然后,开始编译您的busybox.
Hope this information is helpful to you.
Have a nice day!
B.R
Weidong
1,359 次查看
xfg
use .config in busybox   to make and make install (busybox file),different from yocto compile way (busybox.nosuid,busybox.suid  two file)
