I am having a camera, that has 1080p60fps and the 1080p30fps works perfectly fine and the movement i select the 1080p60fps, the mx6_capture.c code selects 720p30fps. Let me know how to make it work..
on IMX8MM - 1080p60fps has been tested?
Santhosh Kumar S
