IMX8MM Docker startup time is more than 5 mins
sundaram_v
Dear Team,
We are utilising a Yocto-based setup for the IMX8MM, and when we run Docker on it, the initial execution of the docker ps command takes more than 5 minutes, after which it runs well. Could you kindly offer some advice on how to speed up the startup of Docker?
Sundar
brian14
Thank you for contacting NXP Support.
About this problem I can suggest implementing a light image on Yocto. For example, instead of using imx-image-full you can use the imx-image-multimedia.
Or also you could try a similar solution as mentioned at this link: How to Optimize Docker Performance (phoenixnap.com)
I hope this information will be helpful.
Have a great day!
