IMX8M nano lpddr4
IMX8M nano lpddr4
1,550 次查看
link
Hi all:
     In our imx8mn+LPDDR4 board, the copy rate of DDR tested with sysbench is 2660 MiB/s.
but in imx8mnEVK(lpddr4) ,the copy rate is 3200 MiB/s.Our board are much slower than imx8mnEVK boards.
    We used MSCALE_DDR_Tool to execute the DDR training, code generation and stress test.There is no problem.
    We want to know what causes this problem?
1,506 次查看
link
The CPU frequency does not increase because the PMIC configuration is abnormal
1,507 次查看
link
1,537 次查看
Rita_Wang
How the LPDDR4 you are using, with the 2660 MiB/s?
