IMX8M nano Android13 upgrate Android15 with OTA package
285 次查看
bert_li
Android13 upgrate Android15 with OTA package, device can not mount the data partition and will boot into recovery mode:
reason is [set_policy_failed:/data/bootchart]
installing_text: en (156 x 19 @ 700)
Command: "/system/bin/recovery" "--prompt_and_wipe_data" "--reason=set_policy_failed:/data/bootchart"
标记 (1)
265 次查看
Zhiming_Liu
Can you share the type of OTA package ? full or incremental? Does incremental and full OTA has same issue?
Zhiming
