Hi joanxie,
Can you please let me know, How to calculate the NVCC_XXX supply rails power consumption in IMX8MQ processor with example?
Thank & Regards,
Karan Chauhan
Hi joanxie,
I have gone through the application note but did not find how to calculate the IO supply voltage for different interface or NVCC_XXX supply rails current consumption.
It would be good if you can provide the calculation or suggest solution which can help us.
Thanks!
Karan Chauhan
for NVCC, you can refer to the data sheet,hope helpful for you
for power consumption, pls refer to the power consumption application note as below:
https://www.nxp.com/docs/en/nxp/application-notes/AN12118.pdf
Hi Joan Xie,
Thanks!
Karan Chauhan
