IMX8M Mini A53 core UART debug
2,662 次查看
suhas_mv
We are using i.MX8M mini (MIMX8MM3CVTKZAA) in our design, when referred to i.MX8M mini EVK schematics (SPF-31399_C2), UART 2 is used for A53 debug and UART 4 is used for M4 debug, is it mandatory to use the same UART's for  A53 debug and M4 debug? Is it possible to move the debug ports to other UART's (i.e. UART 1 and UART 3)?
Suhas
2,650 次查看
Hi suhas_mv
in general yes - it is possible to move the debug ports to other UART's
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8mm-evk.d...
Software changes may be performed for console (uart2) in dts
2,627 次查看
suhas_mv
Thanks for the information
Suhas
