IMX8M MINI Hello world
VinithNama
     I need to excecute an helloworld program in the board , how can i implement a helloworld program
Bio_TICFSL
Hello VinithNama,
The procedure is as follows:
  1. Create a new file called hello.sh using a text editor such as nano or vi: nano hello.sh.
  2. Add the following code: #!/bin/bash. echo "Hello World"
  3. Set the script executable permission by running chmod command: chmod +x hello.sh.
  4. Run or execute the script using following syntax: ./hello.sh.
