dear team, I want to bring up IMX8M MINI board with yocto project build images. I have done with build process as per the steps in document IMXLXYOCTOUG (yocto project user guide) but I stuck in flashing process and I am not able to boot up the board.
BUILD SCENARIO :- $ DISTRO=fsl-imx-wayland MACHINE=imx8mm-lpddr4-evk source imx-setup- release.sh -b build-wayland $ bitbake imx-image-core
Files created in tmp/deploy/images/imx8mm-lpddr4-evk are as follow :-
- Image
- Image--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.bin
- Image-imx8mm-lpddr4-evk.bin
- imx8mm-evk--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-8mic-revE--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-8mic-revE.dtb
- imx8mm-evk-8mic-revE-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-8mic-swpdm--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-8mic-swpdm.dtb
- imx8mm-evk-8mic-swpdm-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-ak4497--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-ak4497.dtb
- imx8mm-evk-ak4497-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-ak5558--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-ak5558.dtb
- imx8mm-evk-ak5558-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-audio-tdm--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-audio-tdm.dtb
- imx8mm-evk-audio-tdm-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-dpdk--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-dpdk.dtb
- imx8mm-evk-dpdk-imx8mm-lpddr4-evk.dtb
- imx8mm-evk.dtb
- imx8mm-evk-ecspi-slave--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-ecspi-slave.dtb
- imx8mm-evk-ecspi-slave-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-inmate--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-inmate.dtb
- imx8mm-evk-inmate-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-lk--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-lk.dtb
- imx8mm-evk-lk-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-pcie-ep--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-pcie-ep.dtb
- imx8mm-evk-pcie-ep-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-qca-wifi--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-qca-wifi.dtb
- imx8mm-evk-qca-wifi-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-revb-qca-wifi--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-revb-qca-wifi.dtb
- imx8mm-evk-revb-qca-wifi-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rm67191--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-rm67191-cmd-ram--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk 20221116140408.dtb
- imx8mm-evk-rm67191-cmd-ram.dtb
- imx8mm-evk-rm67191-cmd-ram-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rm67191.dtb
- imx8mm-evk-rm67191-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rm67199--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-rm67199-cmd-ram--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-rm67199-cmd-ram.dtb
- imx8mm-evk-rm67199-cmd-ram-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rm67199.dtb
- imx8mm-evk-rm67199-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-root--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-root.dtb
- imx8mm-evk-root-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rpmsg--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-rpmsg.dtb
- imx8mm-evk-rpmsg-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rpmsg-wm8524--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-rpmsg-wm8524.dtb
- imx8mm-evk-rpmsg-wm8524-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-rpmsg-wm8524-lpv--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-rpmsg-wm8524-lpv.dtb
- imx8mm-evk-rpmsg-wm8524-lpv-imx8mm-lpddr4-evk.dtb
- imx8mm-evk-usd-wifi--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.dtb
- imx8mm-evk-usd-wifi.dtb
- imx8mm-evk-usd-wifi-imx8mm-lpddr4-evk.dtb
- imx8mm_m4_TCM_hello_world.bin
- imx8mm_m4_TCM_low_power_voice.bin
- imx8mm_m4_TCM_low_power_wakeword.bin
- imx8mm_m4_TCM_rpmsg_lite_pingpong_rtos_linux_remote.bin
- imx8mm_m4_TCM_rpmsg_lite_str_echo_rtos.bin
- imx8mm_m4_TCM_sai_low_power_audio.bin
- imx8mm_m4_TCM_sai_low_power_audio_wm8524.bin
- imx-image-core-imx8mm-lpddr4-evk-20221121131922.rootfs.ext4
- imx-image-core-imx8mm-lpddr4-evk-20221121131922.rootfs.manifest
- imx-image-core-imx8mm-lpddr4-evk-20221121131922.rootfs.tar.bz2
- imx-image-core-imx8mm-lpddr4-evk-20221121131922.testdata.json
- imx-image-core-imx8mm-lpddr4-evk.ext4
- imx-image-core-imx8mm-lpddr4-evk.manifest
- imx-image-core-imx8mm-lpddr4-evk.tar.bz2
- imx-image-core-imx8mm-lpddr4-evk.testdata.json
- lpddr4_pmu_train_1d_dmem.bin
- lpddr4_pmu_train_1d_imem.bin
- lpddr4_pmu_train_2d_dmem.bin
- lpddr4_pmu_train_2d_imem.bin
- modules--5.15.52+git0+36363d8623-r0-imx8mm-lpddr4-evk-20221116140408.tgz
- modules-imx8mm-lpddr4-evk.tgz
- signed_dp_imx8m.bin
- signed_hdmi_imx8m.bin
- tee.bin
- tee.mx8mmevk.bin
- u-boot.bin
- u-boot.bin-emmc
- u-boot-emmc-2022.04-r0.bin
- u-boot-imx8mm-lpddr4-evk.bin
- u-boot-imx8mm-lpddr4-evk.bin-emmc
- u-boot-imx-initial-env-emmc
- u-boot-imx-initial-env-imx8mm-lpddr4-evk-emmc
- u-boot-imx-initial-env-imx8mm-lpddr4-evk-emmc-2022.04-r0
- u-boot-spl.bin
- u-boot-spl.bin-emmc
- u-boot-spl.bin-emmc-2022.04-r0
- u-boot-spl.bin-imx8mm-lpddr4-evk
(some are linked files in this list) please guide me with detailed steps to flsah images using sd card and boot up the board.
from above list, which files to copy in sd card and how?
how to load bootloader?
how to boot up the board?
detailed steps for flashing linux os in sd card and boot up the board with sd card.
(note : i have referred document i.MX Linux ® User's Guide, Rev. LF5.10.52_2.1.0, 15 October 2021, but I could'nt find the image files as mentioned in doc )
Flash tool:https://github.com/NXPmicro/mfgtools
Flash tool document: https://github.com/NXPmicro/mfgtools/releases/download/uuu_1.5.4/UUU.pdf
Please see the EVK dip , you should enter download mode:
