@michael_kjar
Hi Michael,
When I did the ddr stress test for IMX8DXL_B0 unit, I found that no b0 test file exists.
Could you please apply the test file for DXL_B0? Thanks in advance.
Solved! Go to Solution.
The latest DDR tools: DDR stress test and RPA, can be found on this public community page:
i.MX 8/8X Family DDR Tools Release - NXP Community
The DDR tools support and have been tested on DXL B0.
I also recommend for you to follow up with your local engineers on Lily Zhang's team to get training on DDR tools and for real-time support.
Pls refer to the link as below:
“https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8DXL-DDR-Register-Programming-Aid-RP...
Thanks for reply, but the URL can't be opened.
pls check your browser, remove the " in the end of link when you click the link I post
You are right. I can get the ds file from this page, and I also want to get the bin and image file as below:
Do you know where I can get this file from?
Thanks for your reply!
