Depending on applications customer can use Overdrive or Nominal mode for VDD_A35 (Power
supply of Cortex-A35 cluster). For applications, where performance is the main requirement, the
Overdrive mode can be applied; for power saving - Nominal mode may be recommended.
Yuri.
