IMX8 switches modes to achieve adaptive resolution
ximenbingmeng
Can IMX8 set the output resolution at the application layer? Is the setting 8-bit or 10 bit?
Or how to set it to 8-bit or 10 bit in uboot? Similar to the following
setenv mmcargs ${mmcargs} '${video}'
setenv video 'video=HDMI-A-1: 1920x1080@60 '
Zhiming_Liu
If you are using weston, you can try to modify the OUTPUT SECTION in weston.ini
https://manpages.ubuntu.com/manpages/focal/en/man5/weston.ini.5.html
Best Regards
Zhiming
