IMX8 fatal error: attr/xattr.h: No such file or directory
5,379 次查看
nitesh-einfochips
Getting below error we have cleaned once and built it works sometime but not always. What are we missing?
bitbake imx-image-full -c populate_sdk
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:02
Loaded 5217 entries from dependency cache.
WARNING: /home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/sources/meta-timesys-test/recipes-test/timesys-test-project/timesys-test-project.bb: Unable to get checksum for timesys-test-project SRC_URI entry file: file could not be found
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:00:07
Parsing of 3697 .bb files complete (3690 cached, 7 parsed). 5224 targets, 255 skipped, 3 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.44.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-18.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mp-35som"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "5.4-zeus"
TUNE_FEATURES = "aarch64 cortexa53 crc crypto"
TARGET_FPU = ""
meta
meta-poky = "HEAD:d88d62c20d7d8da85f02edb170dae0280624ad7e"
meta-oe
meta-multimedia
meta-python = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b"
meta-freescale = "HEAD:791491437ec86c9d2429163533980dcf81c42890"
meta-freescale-3rdparty = "HEAD:dbcc686f52c3c84db8cb86aa8973a4e373651b98"
meta-freescale-distro = "HEAD:ca27d12e4964d1336e662bcc60184bbff526c857"
meta-bsp
meta-sdk
meta-ml
meta-v2x = "HEAD:72eacb2071749a3d5c0c36fd89914c31a2e0b464"
meta-browser = "HEAD:ee3be3b5986a4aa0e73df2204a625ae1fe5df37e"
meta-ecc508 = "HEAD:9530c7fcf7a45a3af1473e20bc46552639c38cdb"
meta-openssl102 = "HEAD:62952f73851545894544fac5310a37cbffe4edb3"
meta-openssl102-fips = "HEAD:4a71cb60e2d58cbd3babaa034c84decd8fcfbad4"
meta-rust = "HEAD:53bfa324891966a2daf5d36dc13d4a43725aebed"
meta-clang = "HEAD:711e593d5984aad3bf35c51b7ac4482982bc16c7"
meta-iot-cve
meta-iot-cloud
meta-java = "iot-imx8-dev-CPU2.0:c0e8cb77a0e4a4827b37963b1f8d4d1d2132d055"
meta-gnome
meta-networking
meta-filesystems = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b"
meta-qt5 = "HEAD:509be0620f43177a0fa0cec4160aa881d3facef4"
meta-python2 = "HEAD:4400f9155ec193d028208cf0c66aeed2ba2b00ab"
meta-iot-bsp = "iot-imx8-dev-CPU2.0:c0e8cb77a0e4a4827b37963b1f8d4d1d2132d055"
meta-timesys-security = "HEAD:c98c363b8ab5e485a9c499a362595954294fd3cb"
meta-timesys-test
meta-security-isafw = "iot-imx8-dev-CPU2.0:c0e8cb77a0e4a4827b37963b1f8d4d1d2132d055"
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:05
Sstate summary: Wanted 12 Found 5 Missed 7 Current 2433 (41% match, 99% complete)
NOTE: Executing Tasks
NOTE: Setscene tasks completed
ERROR: nativesdk-pseudo-1.9.0+gitAUTOINC+060058bb29-r0 do_compile: oe_runmake failed
ERROR: nativesdk-pseudo-1.9.0+gitAUTOINC+060058bb29-r0 do_compile: Execution of '/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/temp/run.do_compile.14650' failed with exit code 1:
SQLite header for version 3031001 found in /home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr.
Enabling in-memory database by default.
x86_64-pokysdk-linux-gcc --sysroot=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot -fno-strict-aliasing -O2 -pipe -fmacro-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0=/usr/src/debug/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0 -fdebug-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0=/usr/src/debug/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0 -fdebug-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot= -fdebug-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot-native= -pipe -std=gnu99 -Wall -W -Wextra -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -O2 -pipe -fmacro-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0=/usr/src/debug/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0 -fdebug-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0=/usr/src/debug/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0 -fdebug-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot= -fdebug-prefix-map=/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot-native= -DPSEUDO_PREFIX='"/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib/pseudo/lib64"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB -DPSEUDO_FORCE_ASYNC -DPSEUDO_PASSWD_FALLBACK='NULL' -DPSEUDO_XATTR_SUPPORT -DPSEUDO_EPOLL -O2 -g -L/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/lib -I/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/recipe-sysroot/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/include -D_GNU_SOURCE -c -o pseudo_wrappers.o pseudo_wrappers.c
In file included from pseudo_ports.h:15,
from pseudo.h:160,
from pseudo_wrappers.c:30:
ports/linux/xattr/portdefs.h:5:10: fatal error: attr/xattr.h: No such file or directory
5 | #include <attr/xattr.h>
compilation terminated.
Makefile:153: recipe for target 'pseudo_wrappers.o' failed
make: *** [pseudo_wrappers.o] Error 1
WARNING: /home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/temp/run.do_compile.14650:1 exit 1 from 'exit 1'
ERROR: Logfile of failure stored in: /home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/temp/log.do_compile.14650
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: Building/installing only 64-bit libpseudo.so for nativesdk-pseudo.
| NOTE: If you need to run 32-bit executables, ensure that NO32LIBS is set to 0.
| NOTE: make -j 8
| from pseudo.h:160,
| ERROR: oe_runmake failed
| ERROR: Execution of '/home/sujay/imx8_gateway_build/iot-imx8-dev-CPU2.0/build_imx8mp-35som_phx/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-pseudo/1.9.0+gitAUTOINC+060058bb29-r0/temp/run.do_compile.14650' failed with exit code 1:
| from pseudo.h:160,
6 回复数
1,000 次查看
middepogudas
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$ bitbake imx-image-full -c populate_sdk
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:01
Loaded 5449 entries from dependency cache.
WARNING: preferred version 17.0.6 of llvm-native not available (for item llvm-native)
WARNING: versions of llvm-native available: 17.0.3
BB_VERSION = "2.6.0"
NATIVELSBSTRING = "universal"
MACHINE = "imx8mp-lpddr4-evk"
DISTRO_VERSION = "6.6-nanbield"
TUNE_FEATURES = "aarch64 armv8a crc crypto"
TARGET_FPU = ""
meta
meta-poky = "HEAD:046b70083f3bc9e25f547e8026400032f5c563d9"
meta-oe
meta-multimedia
meta-python = "HEAD:1750c66ae8e4268c472c0b2b94748a59d6ef866d"
meta-freescale = "HEAD:0a73d1bdd7713a6189482e463c98043c9939a2a2"
meta-freescale-3rdparty = "HEAD:7725256e3859b62f1ff201db7f2cf7026c17656d"
meta-freescale-distro = "HEAD:4f1f101ebab5eb054bfbed10b247fc0547b30793"
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-imx-v2x = "HEAD:773c0049c3b35af8f5b5bdf8da78a6236a4fc184"
meta-nxp-demo-experience = "HEAD:db34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb"
meta-arm
meta-arm-toolchain = "HEAD:4d22f982bce8dff6f8c4d11845c47a4d39f961c6"
meta-chromium = "HEAD:dc31889c0899971def535dc1c040edf18bc16691"
meta-clang = "HEAD:9b08495e6bcef524789aefb6a7cc80fdfd2ff409"
meta-gnome
meta-networking
meta-filesystems = "HEAD:1750c66ae8e4268c472c0b2b94748a59d6ef866d"
meta-qt6 = "HEAD:fd054cf5fc1b50d50cd606384ab338c6d9206437"
meta-parsec
meta-tpm = "HEAD:070a1e82cc59424d230a23c0b2a104b01fbaa2ad"
meta-virtualization = "HEAD:9e92984ff47b3ca2106b1d27a93af061b28d1e8a"
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:08
Sstate summary: Wanted 7271 Local 0 Mirrors 0 Missed 7271 Current 859 (0% match, 10% complete)
NOTE: No reply from server in 30s (for command ping at 09:14:59.572123)
Timeout while waiting for a reply from the bitbake server (60s at 09:15:29.609589)
5,345 次查看
nitesh-einfochips
Hi Zhiming,
Thanks for your reply. We are using Virtual Machine to build. What you mean by host packages? Will you share some links from where we can download those host packages. Our packages are breaking when we do a build sometimes we are at 90% built and then a package breaks. We have to do clean and then build which takes a lot of time.
5,329 次查看
Zhiming_Liu
1.Install host packages on your host
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat cpio python python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev \
pylint3 xterm rsync curl zstd pzstd lz4c lz4
2.Try to delete your yocto project and re-sync it.Some source code may be lost during downloading.
5,324 次查看
nitesh-einfochips
I tried this command but getting following error:-
Package lz4 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package pzstd
E: Unable to locate package lz4c
E: Package 'lz4' has no installation candidate
5,364 次查看
Zhiming_Liu
Hi @nitesh-einfochips
Do you install all host packages on your PC ?
Zhiming
5,335 次查看
nitesh-einfochips
The issue is in nativesdk-pseudo-1.9.0+gitAUTOINC+060058bb29-r0 do_compile: oe_runmake failed. How to fix this?
