IMX8 audio tunning tool source code support
2,337 次查看
dongyang12
I plan to development the voice algorithm in the IMX8MM. the algorithm is like your Conversa Voice. I also need development the tuning tool for the algorithm. And I find that conversa have tunning tool. And I need the demo code that the Windows PC application how to  interaction with the Conversa software running on the processor. Could you provide the tuning tool source code and the code about windows PC how to communite with the software running in the IMX8.
8 回复数
2,327 次查看
Rita_Wang
Which version BSP are you using? For the i.MX8MM board are you using the NXP reference board or the board you designed yourself?
2,314 次查看
dongyang12
"Real-time_Edge_v2.5_IMX8MM-LPDDR4-EVK.zip" this is the image what I used. And I  using the NXP reference board, the name is 8MMINI-BB.
2,286 次查看
Rita_Wang
@dongyang12 I have confirmed with our expert team that
The conversa tuning tool cannot work with other voice solution. And we have no source code for sharing.
Customer may use different ways for the connection of tuning tool with EVK, some voice solution may use TCP/IP network. Or the host PC can run both voice-call client and the tuning Tool. Through a composite device, both applications share an USB connection for the audio streams and tuning communication.
Hope this can do help for you
Wish you have a nice day
2,280 次查看
dongyang12
Thanks your feedback.
1, And I want to know conversa tuning tool using which way to communicate between Windows PC and host.
2, My requestment is that Windows PC can communicate with host in real time. For example, Windows PC generates a file, which can then be sent to the host folder/tmp/file in real time. And windows PC can get the host data in real time.
About this, do you have any demo code to share us.
2,272 次查看
Rita_Wang
Sorry about that we have no source code for sharing.
2,294 次查看
Rita_Wang
I will confirm it for you and then give you update.
2,308 次查看
Rita_Wang
For the Core board is the 8MMINILPD4-CPU?
2,295 次查看
dongyang12
Yes.
