IMX8 Quad core and Dual core chip Power consumption
nadira
HI,
I am looking for difference in power consumption of IMX8 quad core and Dual core chips, Can anybody suggest me how to calculate difference? or where do i get there data? i am unable to get for only dual core power consumption?
gusarambula
Hello Yaseen Vantmuri,
The only document we have available on this regard is Application Note 12338 (link below), which you have probably already read.
https://www.nxp.com/docs/en/application-note/AN12338.pdf
There is not a dedicated App Note for the Dual version, but it may give a gross estimate if you consider that the VDD_CPU rail (Cortex A35 complex) would power only two cores.
My apologies for the inconvenience.
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
