> How can 'measuring wrong' be a cause? I measure the total current drawn by the board
this is wrong measuring, sorry. Measuring total board current does not make sense as
excessive current may be caused by external board components. So you should make
additional steps to put them in state preventing additional current.
Please reread carefully sect.3.7. Measuring points on the MX6ULL EVK platform
6ULL Power Consumption Application Note
Measuring Current in i.MX Applications
There are special testing points on EVK allowing to measure and verify processor current in
low power states. Note, other board components may be left in active state, though processor
is in low power state, causing overall board current to be not so small as expected.
>I've read the referenced application notes (before i made this thread) that's
>why i'm so surprised about what i measure.
May be suggested to test it on i.MX6ULL EVK NXP reference board.
MCIMX6ULL-EVK|i.MX6ULL Evaluation Kit | NXP
If you are measuring on some third party board suggest to apply to its tech support
for additional help.
