IMX6ULL and DDR3L frequency related query?
1,300 次查看
ramesh6663
In the EVK design have 1 DDR3 DRAM chip which is DDR3-1600. However, the datasheet of iMX6ULL says it only support DDR3-800, which means the bus frequency can only be 400Mhz. I am not sure how to use a higher speed memory with a lower speed CPU. When write data, that may be OK. But when read data, the data strobe is sent by DDR3-1600, which should be 800Mhz. How does it work with iMX6ULL 400Mhz bus frequency?
标记 (2)
1,018 次查看
joanxie
for more detailed information about this, pls refer to the document as below:
https://community.nxp.com/docs/DOC-333791
