I am currently using YOCTO sumo linux kernel L4.14.98-2.3.1 with imx6ul.
In my application, we need to store our secure data (e.g key) inside secure non-volatile storage (SNVS) region. I don't know how to read/write the SNVS from either linux kernel space or user space.
Is there any example of how to read/write SNVS region?
Hi @wayneshih
Have you solved your problem? I have the same needs, I also need to store my secure data inside secure non-volatile storage (SNVS) region,Can you share your experience
Hi wayneshih
for secure ram / secure storage examples one can refer to
AN12554 Demo Application to Generate Red/Black Blobs Using CAAM and Encrypt/Decrypt Data
https://www.nxp.com/docs/en/application-note/AN12554.pdf
https://source.codeaurora.org/external/imxsupport/imx_sec_apps/tree/demo-caam-blobs/README.txt
Thank for your quick reply igor.
The solutions you provide doesn't mention the secure non-volatile storage in imx6ul.
Is it because there is no easy way to access this region or this region is not design for storage security data?
if you are looking for examples for access to snvs registers, one can look at snvs rtc :
https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/rtc/rtc-snvs.c?h=imx_5.4.47_2.2.0
https://source.codeaurora.org/external/imx/imx-test/tree/test/mxc_rtc?h=imx_5.4.47_2.2.0
