IMX6UL NTFS-3G related
Nu-GG
hello.
I have completed a build with "ntfs-3g-ntfsprogs 2017.3.23" in a yocto 3.2 environment.
I can also check the installed packages.
However, there is no executable file, and I get an error when I run it with ntfs-3g in the mount option.
If anyone has experience with this, please help.
Harvey021
It seems telling from the log that the fs not available yet. You might try compile it manually as GitHub - tuxera/ntfs-3g: NTFS-3G Safe Read/Write NTFS Driver.
Harvey
Nu-GG
Thank you for your response.
I will try to find a way to build it.
